Help X on top left of screen
screenshot_20200310-114954_samsung-experience-home.250
I have looked at all my apps and notes i even did a hard restart and nothing all i havnt done is reset it. Its 8.1.0 samsung exp vers 9.5 with metro service
First I would try tapping the 'X' to see what happens.
If nothing, then I would pull down the notifications by swiping from the top of the screen downwards.
All notifications should appear, and when you tap then slide one a bit to the right a settings pinwheel should pop up.
This will take you to the notification settings for the app.
If nonet of your notifications relate to this icon, then go into your developers options.
Check the running apps, and stop each one until the icon disappears.
Don't have Developers Options in your settings?
Open settings, scroll down to About Phone
Tap the Build Number 7 times.
Now when you open Settings, down near the bottom you should see Developers Options.
