X10 Battery Tips
Sometimes, phone battery would be the factor that limit our activities on our phone and it seems like every smartphone user(even myself) encounter a problem with their phone battery. So, I decided to share some times which I got it from a blog.
1) Use TaskPanel/Startup Auditor to prune start-up apps
There are some applications that start by themselves when you switch on your phone. Use these apps to stop those startup apps from running from running on your phone to enhance your battery life and startup speed.
Taskpanel Xtra
2) Lower frequency of Facebook, Picasa, Twitter updates
Go to Settings
If on GB, taskillers and power management apps are not needed, can actually do more bad than good.
on WB gaming rom i use autokiller memory optimizer n go task killer widget. but im always using phone constantly and blasting my music while running apps...so my battery wouldnt last long no matter what i do. the only other tips i can give is get a separate device to play music and uninstall annoying apps that keep running in backround automatically or even just cut down the time you spend using your phone
