Help X10i data issue AT &T
Vehano
Hi Guys
I recently arrived in Miami from south africa and brought my x10i with android 2.3.3 build number 3.0.1.G.0.75 i have debranded the phone to a generic firmware .
i can make calls and receive them, receive texts . but i cant send sms's it says "could not be sent" . Cannot connect to the internet , i have the $50 unlimited package from AT&T and added a $15 data bundle 100mb.
I can click on sony ericsson settings to download the internet and mms settings but it does not download the correct settings.
I have also manually added a variety of APN's which i have found on the web but no luck yet.
Can anybody help Please!
Cheers
Hi Guys
Cheers
Finding the right APN is what you need to do.
You tried this one:
APN: wap.cingular
Proxy: leave blank
Port: leave blank
Username:WAP@CINGULARGPRS.COM
Password:CINGULAR1
Server: leave blank
MMSC: http://mmsc.cingular.com
MMS Proxy: wireless.cingular.com
MMS Port: 80
MCC:310
MNC:410
APN Type: leave blank
And under Network Operators, you need to select the right AT&T. If the 3G AT&T connection doesn't work, take a look to see if their is a 2G one and if it connects.
The X10i is not fully compatible with AT&T's network, you will only get GSM (Edge) for both calls and data. You should use the X10a with AT&T to get 3G. The X10i would work well with T-Mobile if you can switch.
