rob_does_android
Hello,
This little box is so close to replacing my PC but it has a number of frustrating issues that I would like to fix (it's running Android 9.0).
The on screen keyboard won't go away. I have show virtual keyboard turned off in physical keyboard settings but it still appears.
The enter key enters the currently selected key on the physical keyboard instead of enter. I know how to fix this by rooting the device but I don't know how to root the device (and I'd rather not root the device if I can avoid it).
The cursor keys control the selected key on the on screen keyboard instead of the cursor position on the screen.
Selecting a suggested search term in Google Chrome with the mouse while typing in the URL/Search bar doesn't work (does nothing).
If I can fix the on screen keyboard issues this box will be good enough to replace my PC! Any help appreciated.
