Mods xposed framework & # of icons on the home screen [Root only]
VMuser
Is there a way to increase the grid on the home screen using Xposed as the framework? In other words I would like to increase the number of Icons and/or widgets in my home screen without loading a different ROM or using a different Launcher.
Is there a module that can do this?
My device is a Samsung S4 Mini.
Thx
You can define up to 7 rows and 6 columns on the stock launcher using the Xposed module, Gravity Box [KK]. The Jelly Bean version offers similar choices.
Thank you for the input Lucky, but the notes state that this is not compatible with "vastly modified by device manufacturers". I am using a Samsung S4 Mini. The good part is that it is possible.
Any other ideas?
That disclaimer is just to advise people that not all features will work with all devices, and that no assistance will be offered for non-supported devices. The functionality you're after may still work though. Failing that, you could try Wanam Xposed.
Lucky....I have Wanam Xposed, and I installed Gravity Box, but I cans see where I would be able to increase the number of Rows and Columns. I also tried the GEL module, but it wont work with TouchWiz. Any Ideas?
Or If anyone knows where in the system the settings are, let me know.
Thx
R
In Gravity Box, under "Launcher tweaks":
