evil_haxor
I was given a xt1080 for repair
24.13.2.obake-maxx
SU6-7.2
Locked bootloader. No root. No adb access.
System boots but there is constants force close of background processes like gapps and acore.
I wanted to factory reset and I did but on reboot it had all the same apps and user data intact, no factory state.
Changing any config or uninstalling any app result in it being back after reboot.
What I've tried so far:
-Factory option in AP Fastboot menu. Reboots to system with all the data intact.
-Recovery option in AP Fastboot menu. Reboots to bootloader and states "Boot up failed".
-fastboot erase userdata
-fastboot -w
both with the resulting output:
erasing 'userdata'...
OKAY [ 0.500s]
erasing 'cache'...
OKAY [ 0.620s]
finished. total time: 1.120s
but sadly all userdata is sitting there intact after reboot.
I downloaded VZW-4.4.4-SU6-7.2-release-keys.xml.zip. Tried with RSDLite but it didn't detect the device.
I have installed the drivers and MotorolaDeviceManager. So I decompressed the firmware and flashed the partitions
using fastboot in a script. Resulting in all partitions being flashed OK but after reboot the device
was the same as before with all the apps and user data present. Spooky isn't it?
Can some one offer me any advice? Is it a hardware faliure?
Output of the script follows:
C:\Users\ernesto\Downloads\xt1080\ADB&FastBoot_v2.56>mfastboot.exe oem fb_mode_set
< waiting for device >
OKAY [ 0.109s]
finished. total time: 0.109s
C:\Users\ernesto\Downloads\xt1080\ADB&FastBoot_v2.56>mfastboot.exe flash partition gpt.bin
sending 'partition' (32 KB)...
OKAY [ 0.220s]
writing 'partition'...
This may take a few seconds, if a
different partition table is being
flashed since we need to backup
and restore a few partitions
OKAY [ 0.444s]
finished. total time: 0.665s
C:\Users\ernesto\Downloads\xt1080\ADB&FastBoot_v2.56>mfastboot.exe flash motoboot motoboot.img
sending 'motoboot' (1604 KB)...
OKAY [ 0.360s]
writing 'motoboot'...
flashing tz ...
flashing rpm ...
flashing aboot ...
flashing sbl1 ...
flashing sbl2 ...
flashing sbl3 ...
OKAY [ 4.540s]
finished. total time: 4.900s
C:\Users\ernesto\Downloads\xt1080\ADB&FastBoot_v2.56>mfastboot.exe flash logo logo.bin
sending 'logo' (215 KB)...
OKAY [ 0.290s]
writing 'logo'...
OKAY [ 0.811s]
finished. total time: 1.102s
C:\Users\ernesto\Downloads\xt1080\ADB&FastBoot_v2.56>mfastboot.exe flash boot boot.img
sending 'boot' (10240 KB)...
OKAY [ 0.900s]
writing 'boot'...
OKAY [ 1.872s]
finished. total time: 2.772s
C:\Users\ernesto\Downloads\xt1080\ADB&FastBoot_v2.56>mfastboot.exe flash recovery recovery.img
sending 'recovery' (10240 KB)...
OKAY [ 0.900s]
writing 'recovery'...
OKAY [ 1.512s]
finished. total time: 2.412s
C:\Users\ernesto\Downloads\xt1080\ADB&FastBoot_v2.56>mfastboot.exe flash system system.img
sending 'system' (786432 KB)...
OKAY [ 49.426s]
writing 'system'...
OKAY [ 54.106s]
sending 'system' (531955 KB)...
OKAY [ 33.515s]
writing 'system'...
OKAY [ 36.056s]
finished. total time: 173.103s
C:\Users\ernesto\Downloads\xt1080\ADB&FastBoot_v2.56>mfastboot.exe flash modem NON-HLOS.bin
sending 'modem' (54252 KB)...
OKAY [ 3.671s]
writing 'modem'...
OKAY [ 2.330s]
finished. total time: 6.002s
C:\Users\ernesto\Downloads\xt1080\ADB&FastBoot_v2.56>mfastboot.exe erase modemst1
erasing 'modemst1'...
OKAY [ 0.419s]
finished. total time: 0.419s
C:\Users\ernesto\Downloads\xt1080\ADB&FastBoot_v2.56>mfastboot.exe erase modemst2
erasing 'modemst2'...
OKAY [ 0.419s]
C:\Users\ernesto\Downloads\xt1080\ADB&FastBoot_v2.56>mfastboot.exe flash fsg fsg.mbn
sending 'fsg' (538 KB)...
OKAY [ 0.330s]
writing 'fsg'...
OKAY [ 0.761s]
finished. total time: 1.092s
C:\Users\ernesto\Downloads\xt1080\ADB&FastBoot_v2.56>mfastboot.exe erase cache
erasing 'cache'...
OKAY [ 0.649s]
finished. total time: 0.649s
C:\Users\ernesto\Downloads\xt1080\ADB&FastBoot_v2.56>mfastboot.exe erase userdata
OKAY [ 0.540s]
finished. total time: 0.540s
C:\Users\ernesto\Downloads\xt1080\ADB&FastBoot_v2.56>mfastboot.exe erase customize
erasing 'customize'...
OKAY [ 0.150s]
finished. total time: 0.150s
C:\Users\ernesto\Downloads\xt1080\ADB&FastBoot_v2.56>mfastboot.exe erase clogo
erasing 'clogo'...
OKAY [ 0.518s]
finished. total time: 0.518s
C:\Users\ernesto\Downloads\xt1080\ADB&FastBoot_v2.56>mfastboot.exe oem config carrier gsm
Failed to flash config value
OKAY [ 0.149s]
C:\Users\ernesto\Downloads\xt1080\ADB&FastBoot_v2.56>mfastboot.exe oem fb_mode_clear
OKAY [ 0.148s]
finished. total time: 0.148s
C:\Users\ernesto\Downloads\xt1080\ADB&FastBoot_v2.56>mfastboot.exe reboot
rebooting...
finished. total time: 0.002s
24.13.2.obake-maxx
SU6-7.2
-fastboot -w
OKAY [ 0.500s]
erasing 'cache'...
OKAY [ 0.620s]
OKAY [ 0.109s]
OKAY [ 0.220s]
OKAY [ 0.444s]
OKAY [ 0.360s]
flashing tz ...
flashing rpm ...
flashing aboot ...
flashing sbl1 ...
flashing sbl2 ...
flashing sbl3 ...
OKAY [ 4.540s]
OKAY [ 0.290s]
writing 'logo'...
OKAY [ 0.811s]
OKAY [ 0.900s]
writing 'boot'...
OKAY [ 1.872s]
OKAY [ 0.900s]
OKAY [ 1.512s]
OKAY [ 49.426s]
writing 'system'...
OKAY [ 54.106s]
OKAY [ 33.515s]
writing 'system'...
OKAY [ 36.056s]
OKAY [ 3.671s]
writing 'modem'...
OKAY [ 2.330s]
OKAY [ 0.419s]
OKAY [ 0.419s]
OKAY [ 0.330s]
writing 'fsg'...
OKAY [ 0.761s]
erasing 'cache'...
OKAY [ 0.649s]
OKAY [ 0.540s]
OKAY [ 0.150s]
erasing 'clogo'...
OKAY [ 0.518s]
OKAY [ 0.149s]
OKAY [ 0.148s]
rebooting...
