Hi,
I bought my Yarvik Xenta two weeks ago with Android 4.0.4, all working ok.
From Yarvik downloaded new firmware version for Android 4.1.1, it works faster and better, but when i upgraded to this version Contact apps are missing.
I can't use gmail or create new contacts in my tablet because i don't have access to my contacts and sync to my google account.
I have done many tests, extract (wendal's tools) from v4.0.4 ROM and copy with adb to v4.1.1 /system/app following apps:
Contacts.apk
ContactsProvider.apk
GoogleContactsSyncAdapter.apk
it doesn't worked.
I have tested other apk from Custom ROMs but doesn't worked.
I would like to know what apps / files / processes / services are related to contacts management and syncronization and if i could install/inject/overwrite this apps to my tablet to use correctly my contacts.
More info:
Chip Rockchip RK3066 Dual Core Cortex A9 1,66 Ghz
GPU Quan Core Mali 400 Mhz
v4.1.1 Kernel version 3.0.8+ lsd@zed-server3 #35 SMP PREEMPT Sun Oct 7 17:35:59...
Build Number RK30_ANDROID4.1.1-SDK-v1.00.00
ruifu_V2.03.20121009.d4ddc5e
Thanks in advance!
jps
Contacts.apk
it doesn't worked.
More info:
Thanks in advance!
jps
