I hate to start off negative, but please don't reply "Just leave it on the charger for a couple of hours after the green light comes on".
So after about a week with the new 3000mAh chinese battery (from the ebay link posted in another thread), I just don't see any improvements. I've gone through ALL of the battery tips and I won't list them all -- just know that I've done them ALL. The only battery tip that I haven't done is using the setcpu (or whatever) app cause I haven't rooted my evo yet.
Is there any app or widget that lists the actual percentage for these batteries? I'm never done any android development, but ran across this link: Mihai Fonoage's Blog: Getting the Battery Level in Android using the SDK
It seems that all you do is get the EXTRA_LEVEL constant and multiply it by 100, then divide it by the EXTRA_SCALE constant. I tried copying/pasting that all into eclipse - but multiplying the EXTRA_SCALE by 2 so I could get the correct battery level. Of course since I'm a noob it fc'd on me.
Please also don't move this into the developer's forum as this isn't about that. I was just rambling about what I've tried to get the correct battery level to display.
I mean even if I did just leave my phone on the charger for a couple of hours after it shows fully charged (which I've done overnight a couple of times already)... That doesn't seem like it would work. Another guy in another thread posted that he used a killowatt to monitor battery draw and after 90%, the evo very slowly trickle charges for the last 10%. So with another 110% battery charge remaining, wouldn't that trickle charge process take a day or more??
So sorry for the rambling, but I guess my question is... Is there any app/widget that will display the proper battery level? Barring that, what's the best app for tracking my battery usage so I can try to figure out what the problem is?
thanks,
Will
thanks,
Will
