I have 2 of these zoomtak K9 boxes. If I plug the frits one I got into the TV and do a speed test I go at 100 mbs. If I unplug that one and plug the other one in and do a speed test I only get 22 to 28 mbs download. Both have the same upload speed and similar ping times. There are in the same place and only 1 at a time is plugged in and I use the same cables. I have checked all the setting I can think of and they all appear to be the same. Both units take the same IP address, yet there is a big difference in the speed.
Any thoughts of what I could check and or change
Thanks
Water101
Thanks
Water101
