REALOldNick
Member
EDIT: I think it's a dud card. I out it into my other android phone and it seemed to work, but then music started skipping and the phone kept saying that folders and files were missing, when they were there 2 minutes before etc.
I have a Blade C2+ and have just bought a 32GB Micro SD card for it. The phone is supposed to be able to handle 32GB.
When I pout the card in while plugged ito my PC via USB (to transfer audio files) the phone acknowledges that there is an SD card, but says it is unmounted. So I searched how to mount and SD card. Settings/Storage/SD card. But even though the card is in place, there is a message "Insert an SD card to mount".
Then I noticed that if I withdrew the card, waited a few seconds, then reinserted it, the phonw would say "SD card removed"..._when_ I reinserted it!
The card works fine in and android tablet, in that as soon as I put it in the lot, iut is available to be used.
Any ideas anyone?
Thanks for any help
Nick
Any ideas anyone?
Thanks for any help
Nick
