ZTE Citrine storage issues
I have moved all possible apps to the SD card but I'm not able to update because the phone states I don't have enough storage space. The SD card is only about 1/8th full. How do I correct this problem?
Phone has 8 GB internal storage and 16 GB SD card.
Any help would be greatly appreciated. Thanks!
- You could clear all pics, screenshots, videos, and downloads by moving them to external sdcard.
- Some phones will pretend to 'move apps to sdcard' but actually just double the info on internal sdcard anyways since some systems can't properly tell the difference between the two.. So you'll have to move them back and check again to see if it actually freed up space. It's happened to me before on a ZTE, they're what I've been using for a while.. 😎
-- I have the same problem. I have read a lot of negative reviews on ZTE phones in general, and this one is the lowest of their line or close to it. I am going back to Motorola, that is still the best, I have almost always used a Motorola phone, and I also had an HTC, I really like that brand as well. Samsung is not a good one IMO. Had a couple "nice" ones and they both were faulty and far more fragile than any other phone I have ever used.
