OK, so I am still new to this ZTE Valet. I just discovered that the MAPS app has disappeared from my start screen. There is just a blank space there now. How do I get it back? Thanks!
You can go to the Google Play Store and download the app and install it. You can also try powering down, removing the battery for a few seconds, replace it and rebooting the phone.
Maybe you just deleted the shortcut? There should be a shortcut in the app drawer that you can drag to a home screen. Otherwise, check your list of installed apps to see if it is still installed.
