Zte phone
Can you verify the microphone is working by recording something or using "okay Google"?
There are a few things you can look at. First, if it's in a case, take it out and try to call someone. Check your volume settings for calls. If you have a noise cancelling feature try and turn it off. Finally, look in the dialer settings for a mute opition.
I don't have one, nor have I ever seen one, but if they have a headphone jack, it could be the culprit. Has this been a problem with the phone since you got it? or is this something recent.
Phone is brand new zte sent it to me this same thing happened on the other phone that's why the gave me a new one. This phone is only a week old.
Okay. When you say no one can hear you, do they hear anything and the volume is just really low on their end? Or do they hear nothing at all?
I'd try calling yourself on a land line to confirm what ever the actual voice transmission sounds like. You can also check to see if the phone is set to Voice over IP (wifi calling .. which your carrier might not support, hence the dead air).
