ZTE Unico "Easy Mode" home screen replacement ?
oldroadfan
Hello again!
Last Fall, the wife and I bought two ZTE Unico's. She is disabled and has lots of issues using the touchscreen. She had some luck with a stylus but it's still difficult. I was watching one of the TV Shopping networks and they were showing a Samsung (IIRC) and they mentioned that smartphone makers are offering an "Easy mode" screen. It looked right up her alley. The hawker said that it only takes 3 clicks to enable it or disable it.
Is an Easy Node app preloaded some where on Android phones?
If not, does ZTE offer it?
I looked at the Play Store and someone had a simple one but wanted $10 for it. Yikes! Can anyone say "Highway Robbery?" Lol. Sounds like something that Google should just include.
