ZTE Z998 [msm8960] wlan module compile help--from experienced dev
stayboogy
Android Expert
for whatever reason i can not get a working wlan.ko module no matter what prima source i use, whether i add it the proper 8960 kernel source [not hroark13 8x30 source which doesn't work], or if i try to build it using the cm11 repo with it added to vendor/qcom/opensource/wlan/prima
when trying to build using cm11 repo, i cd into the prima directory and execute "mm" after lunching for my cm_coeus-userdebug device config
everything goes fine through kernel compile, but as soon as it's time to build the wifi module i get the "nothing to do for all modules" stop error.
now i'm familiar with all this but i can see no conceivable reason for it to fail as all proper flags are set in the boardconfig and the kernel works just fine but for the stock 4.1.2 system.
anyone out there with any experience??? do i have complete the entire build of cm11 and then try it again??? i'd just like to be able to compile my kernel and the wlan module alone without all the other crap right now just to have a working wlan module that works with my perfectly working kernel source...
Im not familiar at all with this device, however i did ping hroark to see if he can chime in and offer any assistance :).
my kernel source in my cm11 repo, should only be used when building cm11, with my cm11 tree
if you are using a different tree or stock rom it wont work and you should not use it
when you download the kernel source from ZTE, the prima source is broken
what kernel source are you using, do you have it on github ?
thanks for checking in here.
and secondly, i am very very familiar with building kernels and roms so no noob here lol
thirdly, i'm first building kernels to use with the stock system--best starting place in my experience when it comes to porting any cm builds...
***this is a long response but all is important--just so you understand what is going on here***
what i meant was that your kernel source msm8x30 does build and works just fine using your cm_coeus-defconfig which i'm assuming is for the zte radiant--and the prima driver builds fine using that config file--it will not however boot the stock system jelly bean or kitkat system on the ZTE Z998
however, using the config file pulled directly from the ZTE Z998 does not work with your kernel source. several things have to be changed in the config for it to complete building which then produce a non-booting zImage.
I have a kernel source (not sure where i got it from now since i've downloaded so many) that builds using the config pulled from the ZTE Z998 jelly bean system--it builds perfectly and will boot the stock jelly bean system. the only problem is that the stock config does not contain items for the prima wlan driver because it is built externally using the qcom opensource tree during the android build--that is how ZTE built it for the Z998. see attached xml for the device specific repo zte used to make the official kitkat update
now, when i try to add the prima source from your kernel to mine, i get several build errors when it comes time to compile the wlan module. i use 4.6 toolchain as 4.4.3 fails for msm gpu drivers with the kernel source i have--which is not on github yet.
i have a prima source that builds just fine in my kernel--but it produces a 42mb module that does not work in the stock system.
i also have another source for the prima driver that is added to the cm11 repo in vendor/qcom/opensource/wlan/prima which is exactly how it should be to be built externally from the kernel while building android for the device. however, i can never get it to build--when i cd into the directly and issue the mm command, it starts building the kernel using my config, completes, and then starts working on the prima driver but then fails with the "nothing to do for 'ALL MODULES'" stop error. i cannot figure out why.
i also cannot figure out why the 42mb driver will not work, and the stock driver is only 2.1mb.
the xml wouldn't attach--here it is in wrapped in code tags--this is included in the kitkat update files for the ZTE Z998. the important part is the qcom prima wlan info which shows it's built externally not in the kernel
<project name="platform/vendor/qcom-opensource/wlan/prima" path="vendor/qcom/opensource/wlan/prima" revision="b68c6653c9efed4a7a886f2ecd039fee470af2c4" upstream="msm8930-kk-1-76-master"/>
PHP:
<?xml version="1.0" encoding="UTF-8"?>
<manifest>
  <remote fetch="ssh://10.67.16.29:29418/" name="zte" review="ssh://10.67.16.29:29418"/>
  <default remote="zte" revision="msm8930-kk-1-76-master"/>
  <project name="device/common" revision="ef3439bd231e0d0ad843cec4d1869ba5c116145c" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="device/generic/armv7-a-neon" revision="d99215553e51608ad1b366290f06f50dfd23bb02" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="device/generic/common" revision="11c092a6cbfcf6207f07a9a8e3398e747e7f5461" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="device/generic/goldfish" revision="2524d39681566f4eca7afb7950e05ab642978263" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="device/generic/mini-emulator-armv7-a-neon" revision="77bb98e878409fb714738170a2df2df1223dd57b" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="device/generic/mini-emulator-mips" revision="2ff06dda649ba43507a911057f7854a3373ef7d6" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="device/generic/mini-emulator-x86" revision="a2f05b8c5259c232be5b029b2d5e721ba3f70917" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="device/generic/mips" revision="cba3ddadffd8f92b453b74ea1f2886df3be35314" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="device/generic/x86" revision="8933282b14fbbd2f43ff2187174fcdd22bea0ee8" upstream="msm8930-kk-1-76-master"/>
  <project groups="device" name="device/google/accessory/arduino" revision="abc5159a3ca9dbb5c7e364a1eab99901a4440ac5" upstream="msm8930-kk-1-76-master"/>
  <project groups="device" name="device/google/accessory/demokit" revision="7dfe7f89a3b174709c773fe319531006e46440d9" upstream="msm8930-kk-1-76-master"/>
  <project name="device/qcom/common" revision="7ac77e17475c5d4576329a450556e4415a8807c4" upstream="msm8930-kk-1-76-master">
    <copyfile dest="build.sh" src="build.sh"/>
    <copyfile dest="vendor/qcom/build/tasks/generate_extra_images.mk" src="generate_extra_images.mk"/>
  </project>
  <project name="device/qcom/sepolicy" revision="5268dafb389211129c4d0702798b6dd7b6d3ff2a" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="device/sample" revision="af7fc1700746291f6eb1ae76e58b11b83d903c17" upstream="msm8930-kk-1-76-master"/>
  <project name="kernel/lk" path="bootable/bootloader/lk" revision="a0875582d913e74d90609afccadcdb65fa256b21" upstream="msm8930-kk-1-76-master"/>
  <project name="kernel/msm" path="kernel" revision="ffb6bfc0de28089270158275a6ec231b0876d4f7" upstream="msm8930-kk-1-76-master"/>
  <project name="msm8930-proprietary-1-76" path="vendor/qcom/proprietary" revision="5b0a1e42dd1ab0cbb8abc6e5e0d361b853b62116" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/abi/cpp" path="abi/cpp" revision="18f1b5e28734183ff8073fe86dc46bc4ebba8a59" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/art" path="art" revision="0ae399865f9ecc2ec0b35a8e7e84de2125097619" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/bionic" path="bionic" revision="a118f2d330efdd2fb68a5e938a3a1209ef468f12" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/bootable/bootloader/legacy" path="bootable/bootloader/legacy" revision="3c491d6efb8ff2534a6934702760a6273f197918" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/bootable/diskinstaller" path="bootable/diskinstaller" revision="60d078a5924284a452a8fe739247704f8b31c754" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/bootable/recovery" path="bootable/recovery" revision="1b1a47af2178626ed6fca300cf95c06f7403bcb0" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/build" path="build" revision="097922ac3a9e5d899e4c025a66f44ab0bd7cb149" upstream="msm8930-kk-1-76-master">
    <copyfile dest="Makefile" src="core/root.mk"/>
  </project>
  <project groups="cts" name="platform/cts" path="cts" revision="3fb7b9d2c8f05046882222f66d93ec757aede981" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/dalvik" path="dalvik" revision="b1a809734942013caee3d3d707db033839a6cc32" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/developers/build" path="developers/build" revision="1befc5c497614e1119c8b21483f2f55de9465210" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/developers/demos" path="developers/demos" revision="a7254542b06878f0c3b34a6c3d91b9e7d3990f74" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/developers/docs" path="developers/docs" revision="c0b835ddd9acc27176dc9a0f7d1aa2faf5d51806" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/developers/samples/android" path="developers/samples/android" revision="d39eecb7e6781d73c6eea8ea9aed7c6746430aaa" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/development" path="development" revision="350532a2b476bcbf45af5f6aa76660aad137ba7d" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/docs/source.android.com" path="docs/source.android.com" revision="48fb042cf314333926a5146ee7acc004a9e953c8" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/aac" path="external/aac" revision="fa3eba16446cc8f2f5e2dfc20d86a49dbd37299e" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/android-clat" path="external/android-clat" revision="2a3184670060e41450f50709b75356b66554e970" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/android-mock" path="external/android-mock" revision="1922306d33d16f143d5a01daebba4e2cb477d0f5" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/ant-glob" path="external/ant-glob" revision="0f189400fd2a36bf11bfb058e7f3917eb7ed163a" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/ant-wireless/ant_native" path="external/ant-wireless/ant_native" revision="253a2f22f5e78bcb5875da1815d0733f84f9adcb" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/ant-wireless/ant_service" path="external/ant-wireless/ant_service" revision="5c9ec1753dfcb83b98c26354d92d05f4be4fd808" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/antlr" path="external/antlr" revision="47997265eeb7d954a32ece693bbe6dab740872dd" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/apache-harmony" path="external/apache-harmony" revision="12bb45ab43a92cbac0fdb111011906e3c123abec" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/apache-http" path="external/apache-http" revision="e42d321e4b3f47a044f8bab9d5bf704dcc1d7ee4" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/apache-qp" path="external/apache-qp" revision="64ea622b23e6612eb8e7dcae6bfd4314beb022a8" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/apache-xml" path="external/apache-xml" revision="2aee886cec3ee44b3df9fd3ab7ac6d01efd592c0" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/arduino" path="external/arduino" revision="d06daf9bbc46838400461eb8e15842974e38d82a" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/bison" path="external/bison" revision="c2418b886165add7f5a31fc5609f0ce2d004a90e" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/blktrace" path="external/blktrace" revision="d345431f16b8f76f30a58193ff2b26d5853e1109" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/bluetooth/bluedroid" path="external/bluetooth/bluedroid" revision="78ad44ae597ccf0c8aeb4d38a7d08dfecc599f87" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/bouncycastle" path="external/bouncycastle" revision="1226752ab39815d0cbc78beab9bc9c4460f8932f" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/bsdiff" path="external/bsdiff" revision="23e322ab19fb7d74c2c37e40ce364d9f709bdcee" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/bson" path="external/bson" revision="ad6fc5dbb5f4369e08f7543b1517c225281900c0" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/bzip2" path="external/bzip2" revision="1cb636bd8e9e5cdfd5d5b2909a122f6e80db62de" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/ceres-solver" path="external/ceres-solver" revision="399f7d09e0c45af54b77b4ab9508d6f23759b927" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/checkpolicy" path="external/checkpolicy" revision="0d73ef7049feee794f14cf1af88d05dae8139914" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/chromium" path="external/chromium" revision="d8d0d5cef636d5456bf5f3645959409bdc5499aa" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/chromium-libpac" path="external/chromium-libpac" revision="f34af54bcab917eb5943d1918f32d26364f45578" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/chromium-trace" path="external/chromium-trace" revision="8252ae6b83ea65cf871e7981e981da07379f5a0f" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/chromium_org" path="external/chromium_org" revision="2ac7c98a82e5e1384ffac6e5acf13471944a112b" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/chromium_org/sdch/open-vcdiff" path="external/chromium_org/sdch/open-vcdiff" revision="e485ff1fb732be2dff497b6aed11d5c0d681de82" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/chromium_org/testing/gtest" path="external/chromium_org/testing/gtest" revision="94e12ba7aac661c8b807240f761d91062e9bbd5d" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/chromium_org/third_party/WebKit" path="external/chromium_org/third_party/WebKit" revision="ed1823d234710d7717c44e31fa4d3e773544668b" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/chromium_org/third_party/angle" path="external/chromium_org/third_party/angle" revision="b66a170dc2a090787fc7b4d532c3f9917b6f1b83" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/chromium_org/third_party/eyesfree/src/android/java/src/com/googlecode/eyesfree/braille" path="external/chromium_org/third_party/eyesfree/src/android/java/src/com/googlecode/eyesfree/braille" revision="bb4c72f1deb0b8b2b0468b0bf1050462ebcf6135" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/chromium_org/third_party/freetype" path="external/chromium_org/third_party/freetype" revision="4d7d9cdedfd85c104459daa5ed1fc45688016591" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/chromium_org/third_party/icu" path="external/chromium_org/third_party/icu" revision="ab558fb4a919804f14e33fc89d45b99dbe0c16b2" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/chromium_org/third_party/leveldatabase/src" path="external/chromium_org/third_party/leveldatabase/src" revision="37e8a44acfc54763a96decaac888f06da5985d14" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/chromium_org/third_party/libjingle/source/talk" path="external/chromium_org/third_party/libjingle/source/talk" revision="9b17c8660eabf6335460ed3902a4ab0e760d962a" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/chromium_org/third_party/libphonenumber/src/phonenumbers" path="external/chromium_org/third_party/libphonenumber/src/phonenumbers" revision="c60e18ff4aee521c25afc696a70f9a3c3fa0f167" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/chromium_org/third_party/libphonenumber/src/resources" path="external/chromium_org/third_party/libphonenumber/src/resources" revision="8bebdfad8389093b8f35dbe338dda6bc22c6ba65" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/chromium_org/third_party/mesa/src" path="external/chromium_org/third_party/mesa/src" revision="0d49547f2b1a94e9e8766e21d06ddd4108fc2e69" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/chromium_org/third_party/openssl" path="external/chromium_org/third_party/openssl" revision="baac2e6e88d5c7d1c294a09fcc085b343a830272" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/chromium_org/third_party/opus/src" path="external/chromium_org/third_party/opus/src" revision="12362fc920e19f18d50754c3d1b318af5309b0c2" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/chromium_org/third_party/ots" path="external/chromium_org/third_party/ots" revision="f638bf82d25fc1bedded050acddd0a4a04663341" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/chromium_org/third_party/sfntly/cpp/src" path="external/chromium_org/third_party/sfntly/cpp/src" revision="58f132533b4126b00bc71fd9aed69ecf568cdf39" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/chromium_org/third_party/skia/gyp" path="external/chromium_org/third_party/skia/gyp" revision="569c52752c9d133a25b012c27d7bc5f52ea5d5cc" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/chromium_org/third_party/skia/include" path="external/chromium_org/third_party/skia/include" revision="d38783d78d17488d08aec5690653a30240b1283c" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/chromium_org/third_party/skia/src" path="external/chromium_org/third_party/skia/src" revision="a5854214d7ba2aba8cc5d64482f24ab3265f22dc" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/chromium_org/third_party/smhasher/src" path="external/chromium_org/third_party/smhasher/src" revision="262a4a0c4ba340e863c7e693672156ff2fee0715" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/chromium_org/third_party/yasm/source/patched-yasm" path="external/chromium_org/third_party/yasm/source/patched-yasm" revision="c580f3c787d8ad2dcccceb4438b7572d9713a296" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/chromium_org/tools/grit" path="external/chromium_org/tools/grit" revision="d8b99843356195685e49d52436465c11ab18fa64" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/chromium_org/tools/gyp" path="external/chromium_org/tools/gyp" revision="d0d288d2f7ac3d94f79b7d28a8be329812febd6b" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/chromium_org/v8" path="external/chromium_org/v8" revision="1efc3557e515b1e755a4f8e4df56fccb65f69967" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/clang" path="external/clang" revision="a902511dd22624b15cc61e36d167d1cf3549bc74" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/compiler-rt" path="external/compiler-rt" revision="7cba5f1d950495b02bc8da53d27bdbb1b0d4f117" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/connectivity" path="external/connectivity" revision="3a664fa51724a37727dc713d0d77bea70219ab18" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/curl" path="external/curl" revision="e68addd988448959ea8157c5de637346b4180c33" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/dexmaker" path="external/dexmaker" revision="941ffcf02858a69d6c84417acc420dc9ec14aa7b" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/dhcpcd" path="external/dhcpcd" revision="4f3886675cb4610f6783077f7319d208d516788b" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/dnsmasq" path="external/dnsmasq" revision="e60a5b9d2947e93b7fa8953a9e7a7ba59787304d" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/doclava" path="external/doclava" revision="60222cb991bb0196f333197ab98ae43a4ae9b9ce" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/droiddriver" path="external/droiddriver" revision="21a0001e2426644dd68e6140b5873ebaeafcc3dc" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/dropbear" path="external/dropbear" revision="a34ddbe3819bc465968f3676c734b405e655f8b7" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/e2fsprogs" path="external/e2fsprogs" revision="6f839f13400b94fc99de160e0a8c9c450f253a8e" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/easymock" path="external/easymock" revision="c9a234086537e5fd820b110bbd99e3cdc695004c" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/eclipse-basebuilder" path="external/eclipse-basebuilder" revision="6134da6347cc997e0cf2921aaadfb46f21c05d85" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/eclipse-windowbuilder" path="external/eclipse-windowbuilder" revision="a5f3ee137e94737538ec3bdf9b3716765d178c17" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/eigen" path="external/eigen" revision="c976ec520cf9689a5f29959b59f53a8abb04857f" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/elfutils" path="external/elfutils" revision="b23b2dfb354b3ccf5d1c5d39815f02e7048cf516" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/embunit" path="external/embunit" revision="336b7c65098af0d1be69f2db55f4e75342d73b3f" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/emma" path="external/emma" revision="77c73b8b1a0c9e33bf48ebc3212d439e46d3094d" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/esd" path="external/esd" revision="224a67f2683a7ee997179fc5dd16115e39987b0f" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/expat" path="external/expat" revision="0af0cb3bc7519e567bd9daff3dcd315ab0134a99" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/eyes-free" path="external/eyes-free" revision="16bd4c7a4d1bfe229068b637614dad7c48dd2ceb" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/fdlibm" path="external/fdlibm" revision="0da5f683c9ddc9442af3b389b4220e91ccffb320" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/flac" path="external/flac" revision="2ac44d79f0d4f891b4bee20b852ec0b51f0c6ffb" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/freetype" path="external/freetype" revision="899c67b6cfcd2010784fbf08c5415af16c526e0c" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/fsck_msdos" path="external/fsck_msdos" revision="b29d1cabd7974e351c002d401037d6527ea3bf5b" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/ganymed-ssh2" path="external/ganymed-ssh2" revision="d3724dabc1cfbacd105fe6c422b4dcba80e4fb2d" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/gcc-demangle" path="external/gcc-demangle" revision="9241386b62c353302c2f9eccda0672685b252b4d" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/genext2fs" path="external/genext2fs" revision="e11a9c7fe6f1cef99aad2f25afaea37b72fe9f93" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/giflib" path="external/giflib" revision="9aef3ea079a57c98a9207f8c3b95a5dc08ee74b5" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/google-diff-match-patch" path="external/google-diff-match-patch" revision="cecbe12841337860291c2d6a5728b681ec5fca2a" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/grub" path="external/grub" revision="5c3bee7defca81362e98cf8fbd6c20cf47dff00b" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/gtest" path="external/gtest" revision="0f1ce3dd0b880b6ae0cf7f5413702b8ef542efb2" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/guava" path="external/guava" revision="87ffc45d2619a0c178a058de887e3050bb577efe" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/hamcrest" path="external/hamcrest" revision="69985f92e2ce80184915655cd0d3dfea78a39900" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/harfbuzz" path="external/harfbuzz" revision="858f2d28ac741ef139f74bdbdbcefa7560f17c91" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/harfbuzz_ng" path="external/harfbuzz_ng" revision="3309edccdbc2a92eb03a285abb27c1c1c4a88e43" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/hyphenation" path="external/hyphenation" revision="bfa84834dfeb7fe8d058c2e7e07b5981451ddf82" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/icu4c" path="external/icu4c" revision="74e80701e8f4b16e597fce586f549c0011800697" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/iproute2" path="external/iproute2" revision="f5b6c094b1517e3b9ecee9500b401ad4715ac796" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/ipsec-tools" path="external/ipsec-tools" revision="f4cb1ee4b00abbfb6f968dc25818c23b4b47e584" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/iptables" path="external/iptables" revision="3e87b731a6ffad00c02b0b966fc6ff1435469efd" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/iputils" path="external/iputils" revision="acadef7a134ea68e65f017078f6c6af56d75dcbf" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/jack" path="external/jack" revision="5ceb2025ac5d25ed48183ac2d3dac4691fe761fb" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/javasqlite" path="external/javasqlite" revision="3b4db8854c911edfd02f5c6b8ef625084a0f5a93" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/javassist" path="external/javassist" revision="9566207cff5871c672fac1f0d4332d93292036d7" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/jdiff" path="external/jdiff" revision="e4694302d6a3786c64d954e0b3cf42786283bd3c" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/jhead" path="external/jhead" revision="fc0f7580fb0f1545168e142ab4d886e3c1782711" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/jmdns" path="external/jmdns" revision="f4eb7466d5c09098f9dc54137ed3235e3c43fc9f" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/jmonkeyengine" path="external/jmonkeyengine" revision="a6b44658eb1c55295f132a36233a11aa2bd8f9cf" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/jpeg" path="external/jpeg" revision="615255ab4f52c55dd29e04a97d0e8e53aea7cdb2" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/jsilver" path="external/jsilver" revision="601ffd7efb82f3dce1c1840b5f8e6c759414cdd1" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/jsr305" path="external/jsr305" revision="a82868820d6350811b9ddfde4bf8ed5016084269" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/junit" path="external/junit" revision="190925c4789aebbb3efba1625b4d588bede1cb92" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/kernel-headers" path="external/kernel-headers" revision="87301ad72b24abd9bd75f3f61b1e6e1e22affe7c" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/libcap-ng" path="external/libcap-ng" revision="1d1011a3c5049a7f9eef99d22f3704e4367579cc" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/libexif" path="external/libexif" revision="25d371312cee1452a2adcf8b7f6cad6267bda32d" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/libffi" path="external/libffi" revision="bcb9a592a47ec641d7cec89e10fcf556132713aa" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/libgsm" path="external/libgsm" revision="50761abed8f4734970874165b386cfd4d9599db4" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/liblzf" path="external/liblzf" revision="6946aa575b0949d045722794850896099d937cbb" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/libmtp" path="external/libmtp" revision="7075348937f6a8c9d9211942fcb6c376f4227776" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/libnfc-nci" path="external/libnfc-nci" revision="7d02396e0958e1426c42fef88b68d98cb39c4dee" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/libnfc-nxp" path="external/libnfc-nxp" revision="80a134cf5e011fe35b69bc9ea16a1f494f96a211" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/libnl-headers" path="external/libnl-headers" revision="173c62f4117263f174bb285816b0cc9cb8450602" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/libogg" path="external/libogg" revision="ec0b24fb1468abe37be4164a6feb16568e036bde" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/libpcap" path="external/libpcap" revision="3a7bce5dda6a8db92c9248846d0255e68c3a5b2a" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/libphonenumber" path="external/libphonenumber" revision="485e6d5c6e48a1fc43cc0a090e687c723dac056c" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/libpng" path="external/libpng" revision="877a40c9fd4ffa928ea203abaeffa18051c8e378" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/libppp" path="external/libppp" revision="706e567fc5ff6b79738a5f470e5aa7b2cae76459" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/libselinux" path="external/libselinux" revision="f88035b59f041fae342b3a924277344a473e34a1" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/libsepol" path="external/libsepol" revision="6d4de9be17adf73a89e9d9f5ead058c5b18df902" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/libssh2" path="external/libssh2" revision="2bb40f2445cab3ba588efb29e1835cdba2b27248" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/libusb" path="external/libusb" revision="2801917fe150393d4f4a354165fe89550ae22613" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/libusb-compat" path="external/libusb-compat" revision="94867ba54eb7faa8efca81cf2214d00bb9143d27" upstream="msm8930-kk-1-76-master"/>
  <project groups="libusb_aah" name="platform/external/libusb_aah" path="external/libusb_aah" revision="14419c9d3d0a82243f69238ce927edb52bf3d727" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/libvorbis" path="external/libvorbis" revision="de559619fd4dd0d2d9608436696fd44bdf74eba8" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/libvpx" path="external/libvpx" revision="ef02332fc3e835d385ff02d26a8141cf113424c1" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/libxml2" path="external/libxml2" revision="56d2590ef715e6f2c155d1ec348a7e62c5894092" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/libxslt" path="external/libxslt" revision="98f5140c33273d3bd67ca03566f8417406001016" upstream="msm8930-kk-1-76-master"/>
  <project groups="libyuv" name="platform/external/libyuv" path="external/libyuv" revision="482a582884351288fb701532359652970b1ba7c0" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/linux-tools-perf" path="external/linux-tools-perf" revision="2db19c77b59c71eef27e9876d4c09ceb6966608d" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/littlemock" path="external/littlemock" revision="328b01eada8965cd38feea884d4080c31e3763b0" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/llvm" path="external/llvm" revision="5d63c52424acc972d6370c50e1f3930d695790b7" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/lzma" path="external/lzma" revision="baa3858d3f5d128a5c8466b700098109edcad5f2" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/marisa-trie" path="external/marisa-trie" revision="629ed059b1e85cd8e4de363d8b3dc53c15c3e08a" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/markdown" path="external/markdown" revision="6f2e3554ae38cc90518d32e02cb57d05988270a6" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/mdnsresponder" path="external/mdnsresponder" revision="c46f53f5e072f23051c4eedef730386f7634dc11" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/mesa3d" path="external/mesa3d" revision="b9ba3f4ef0bc010edf2999fe4ac1ac7883bc288a" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/mksh" path="external/mksh" revision="f8c396c4d446a038358106a301b329607a04633d" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/mockito" path="external/mockito" revision="34f80a94e45f7110ec3444c1d0ecfacc194d009a" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/mockwebserver" path="external/mockwebserver" revision="e44762f71ed6eeb718a0bb6f3848beb7696fd97d" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/mp4parser" path="external/mp4parser" revision="16051e950485c6b62127c0446a760111de1a0cb9" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/mtpd" path="external/mtpd" revision="141f77c33bb1f6e4e19b7baff08d963f341e9eb7" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/naver-fonts" path="external/naver-fonts" revision="9238a39d60763f81b98d96f02b087d52b9d4fd52" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/netcat" path="external/netcat" revision="444644cfa9a2f3002863caa168fb2d6b34dfd1e8" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/netperf" path="external/netperf" revision="58ecd3b7c76263900e38921360e334a416aec362" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/neven" path="external/neven" revision="a800c667ea0839a5b28931270cd78385533e6c9d" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/nist-pkits" path="external/nist-pkits" revision="ad3f12ec91a6b419bbf4b24b619ed39bf04589ea" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/nist-sip" path="external/nist-sip" revision="b23dbfce7ea84c39cea75b612868a5832cb9af2b" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/noto-fonts" path="external/noto-fonts" revision="90372d894b5d9c9f2a111315d2eb3b8de1979ee4" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/oauth" path="external/oauth" revision="bc170f58de82000ed6460f111686a850a1890c07" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/objenesis" path="external/objenesis" revision="e8740d2e04179cd15a85dd055cac90b5aeb52589" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/okhttp" path="external/okhttp" revision="e7e700f5ded93b1fe84de2bd1c5c49212c3d6776" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/open-vcdiff" path="external/open-vcdiff" revision="6d29f2f083baf8250db94ed0b4807e513a84163d" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/opencv" path="external/opencv" revision="1691b57dbad9cfc15b9a8b72f8b376733b934ffe" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/openfst" path="external/openfst" revision="5bf56ba7027cd5f22ff52d0138893f7a585135fb" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/openssh" path="external/openssh" revision="47da33088eb8dc14f930f09ba0b5b4ff017b0002" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/openssl" path="external/openssl" revision="b734bc2d00d3d8c6259151f9cea880e56f74e7bc" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/oprofile" path="external/oprofile" revision="4886329fd53290061515485e7cf3ce497fc1b5b9" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/pixman" path="external/pixman" revision="70005f9fa14753353faf0fe2e57359913ed3e75a" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/ppp" path="external/ppp" revision="8594280b43c590a8ad087976406be1cd95756743" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk-java" name="platform/external/proguard" path="external/proguard" revision="54f59ac04f3e21d5aecdd46bb1e7f4577924ab92" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/protobuf" path="external/protobuf" revision="48ee66d295979372ed0234cefda42385daae8312" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/protobuf-c" path="external/protobuf-c" revision="f5acb16b4e8b57f5be4083960023982443bddbca" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/qemu" path="external/qemu" revision="85110a9e6a8ba4df5e3b83a9682792f73ff9817b" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/qemu-pc-bios" path="external/qemu-pc-bios" revision="20349dae98d7de09a7e390d4a706c64f1db6edc2" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/qrngd" path="external/qrngd" revision="fe614bb445337a1cdb8f90cb25cd73f1d37e87b8" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/quake" path="external/quake" revision="0d3007afa9ce224e5dffe65382b425c7317ad4f5" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/regex-re2" path="external/regex-re2" revision="0d4c52358a1af421705c54bd8a9fdd8a30558a2e" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/replicaisland" path="external/replicaisland" revision="99e2e54c5d036048caf09bb05eea0969de093104" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/robolectric" path="external/robolectric" revision="6bf395c984ed3f69711663b006aeffbb0f7e8a90" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/safe-iop" path="external/safe-iop" revision="aa0725fb1da35e47676b6da30009322eb5ed59be" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/scrypt" path="external/scrypt" revision="eb05b73c3bba21fff55529813109de4bad5ddbd1" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/sepolicy" path="external/sepolicy" revision="dcec25bd18d652ad49b70729421b19457bb4581e" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/sfntly" path="external/sfntly" revision="30d4e1f3d81ad9f7a1aa14ce6d2ceb5df56c15cd" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/sil-fonts" path="external/sil-fonts" revision="795a2f4339f8a82d6cff187e2a77bb01d5911aac" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/skia" path="external/skia" revision="bb2fddf9f7d7487011272eb71aaf0d4c525e1a36" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/smack" path="external/smack" revision="d7955ce24d294fb2014c59d11fca184471056f44" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/smali" path="external/smali" revision="884603f0d1cb4df6d1d192b7eaf8e5edb643a9f3" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/sonivox" path="external/sonivox" revision="db3f0921b7f84d151cb597e2c5bc69222385b462" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/speex" path="external/speex" revision="fb7db5853ffb841a4d32fea8b5c3a43e6b875cae" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/sqlite" path="external/sqlite" revision="7b3aeb7cdfc01283fdec59c6b957bb278b46a74e" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/srec" path="external/srec" revision="2706e1ca0c118cb78fbbbc977e4e95e14fdedebc" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/srtp" path="external/srtp" revision="c9e44e6bd5503e1dcd0c19b02763a673664a17f2" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/stlport" path="external/stlport" revision="628e14d37c5b239839a466e81c74bf66255b770b" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/strace" path="external/strace" revision="1a4e05d53dec658a061acb9869cb1eb1342cd09d" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/stressapptest" path="external/stressapptest" revision="0956427aa995561acb4471764158ae057a36dad5" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/svox" path="external/svox" revision="b962ce2a20b17ae0ef8842b4f9c5cdd36a2d3b25" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/tagsoup" path="external/tagsoup" revision="68c2ec9e0acdb3214b7fb91dbab8c9fab8736817" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/tcpdump" path="external/tcpdump" revision="af17a91901f94a67153815e33d4525600dc3ca77" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/timezonepicker-support" path="external/timezonepicker-support" revision="99e91a76fd74bad10266623d67cdb98d011f709e" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/tinyalsa" path="external/tinyalsa" revision="c1b682efcd3b3eac3101408231b58ea92c668756" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/tinycompress" path="external/tinycompress" revision="25c4e0ceeb8e78a7c98535da138af70a0b731e68" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/tinyxml" path="external/tinyxml" revision="494e448824844d866e805831d1d5f5acb654065c" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/tinyxml2" path="external/tinyxml2" revision="d8dc24422f295c6443d8bcc0b3e349f7c8945bb8" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/tremolo" path="external/tremolo" revision="6e5d017716677a63918475b8d89d298b0a4825ec" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/v8" path="external/v8" revision="f53dc205fc8ac4f3e92cb554eb15ef0588667a4b" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/valgrind" path="external/valgrind" revision="99cfba5460bef5032a52e432ce0936b731e6d8e2" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/webkit" path="external/webkit" revision="4512370e24d839ca4ec92eed9f0d5836345e39bc" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/webp" path="external/webp" revision="513e97bd307573e2adc776eb5368bd129aceaa4a" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/webrtc" path="external/webrtc" revision="446452f84e9cc4c75d8e80f6f05e24793397a19d" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/wpa_supplicant_8" path="external/wpa_supplicant_8" revision="2942dc5267a6ac388661289232cf958a7673c854" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/xmlwriter" path="external/xmlwriter" revision="e95d92246ee35273dde2bee8b00485cc14c12be5" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/xmp_toolkit" path="external/xmp_toolkit" revision="42ea4dc6d1fc2206a7778029070ed9213e3b0fbf" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/yaffs2" path="external/yaffs2" revision="a2cff2275e1b501ff478b03757d6e4f05fddc2db" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/external/zlib" path="external/zlib" revision="25d39d6b119e6995595d6a3158afb229d68fbce1" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/external/zxing" path="external/zxing" revision="7620644768ffc235607b3a94671e49518c18686f" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/frameworks/av" path="frameworks/av" revision="ce1a1f3414162e4c5d916765baeed105adf648f4" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/frameworks/base" path="frameworks/base" revision="b1d90588e343dba238b5e63ed62cfa81a24b9c4a" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/frameworks/compile/libbcc" path="frameworks/compile/libbcc" revision="06939316d97f5a72aeb5cd1ad6e8dfae143309b7" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/frameworks/compile/mclinker" path="frameworks/compile/mclinker" revision="89a5648fcb366adb25b75aa69a7ad9a34842dd17" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/frameworks/compile/slang" path="frameworks/compile/slang" revision="0af057c4f43831caa9c1ca182cb0529e82699053" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/frameworks/ex" path="frameworks/ex" revision="0bc971aaf642a70d2d950ba4e15563dc25284321" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/frameworks/mff" path="frameworks/mff" revision="b9669b8540a1e5c953374d53b115514335e23c27" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/frameworks/ml" path="frameworks/ml" revision="5072d507df1fd827ac7b15900c1f113949f76f12" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/frameworks/native" path="frameworks/native" revision="6a73dbd7e35b1e7b875d399dd829f7ccaf2cc696" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/frameworks/opt/calendar" path="frameworks/opt/calendar" revision="fa5be7d6ab908899d376281a8e1120b0b9bcb158" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/frameworks/opt/carddav" path="frameworks/opt/carddav" revision="f08aa2df132dd8dc32a0013d3750137d9dd9280a" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/frameworks/opt/colorpicker" path="frameworks/opt/colorpicker" revision="2426778124b33afac9b53b5072423f8edbaa9310" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/frameworks/opt/connectivity" path="frameworks/opt/connectivity" revision="ec022329188be8d4d8abc47278b61b20e54721d7" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/frameworks/opt/datetimepicker" path="frameworks/opt/datetimepicker" revision="e1a99a2444f1f95c9f96c8d69c75d1adb3846464" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/frameworks/opt/emoji" path="frameworks/opt/emoji" revision="dbbe673145107e99883f62bafd70c5f43f11065c" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/frameworks/opt/inputmethodcommon" path="frameworks/opt/inputmethodcommon" revision="df9dd39c2047992a43b64e13bb0fc348a1630f3b" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/frameworks/opt/mailcommon" path="frameworks/opt/mailcommon" revision="17b68a6f3ce40aa8059595cf6b4b69c008d7dfd9" upstream="msm8930-kk-1-76-master"/>
  <project groups="default" name="platform/frameworks/opt/mms" path="frameworks/opt/mms" revision="b4274cf43a875160c95bb9616509fefc3a27f280" upstream="kk-default-ccs"/>
  <project name="platform/frameworks/opt/net/voip" path="frameworks/opt/net/voip" revision="b51ed34abbb70994da221c545678d9dc5fe88141" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/frameworks/opt/photoviewer" path="frameworks/opt/photoviewer" revision="b5da17aff27a9fbc5c5f13351083f598381fca4e" upstream="msm8930-kk-1-76-master"/>
  <project groups="default" name="platform/frameworks/opt/telephony" path="frameworks/opt/telephony" revision="e16ab8f7e3a71187807b99caa92d3e61f0a4b93d" upstream="8930KK-ccs"/>
  <project groups="default" name="platform/frameworks/opt/telephony-msim" path="frameworks/opt/telephony-msim" revision="4051a7197edf1a9154d06f37768228af9b776097" upstream="8930KK-ccs"/>
  <project name="platform/frameworks/opt/timezonepicker" path="frameworks/opt/timezonepicker" revision="05e0c68677236f3a10e0b4882205971108368c76" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/frameworks/opt/vcard" path="frameworks/opt/vcard" revision="5f55ee296e26d5278fd0d91657edddc92766459e" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/frameworks/opt/widget" path="frameworks/opt/widget" revision="466e0e0307b3f6aa4f4be3d9419b5996bd389da5" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/frameworks/rs" path="frameworks/rs" revision="3da3559d203401b1fa5de168c6987caf941f406d" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/frameworks/support" path="frameworks/support" revision="df7032efe8edf717d1af1c98f275d6f761484ce9" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/frameworks/testing" path="frameworks/testing" revision="136b86103070bf478d3521b80f559701b6f05e3b" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/frameworks/volley" path="frameworks/volley" revision="bd04632e0c5b4a29889c1b70089ac2322229b5e6" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/frameworks/webview" path="frameworks/webview" revision="7c3a3ba66552fc990c92c5d7f46468ee7955e405" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/frameworks/wilhelm" path="frameworks/wilhelm" revision="5bc3ac6c20b5cbb21118b5e8c2c6e25c48ba6026" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/hardware/akm" path="hardware/akm" revision="b20ac242f78561b57cdcb8d37a81dc653d1e1ea4" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/hardware/broadcom/libbt" path="hardware/broadcom/libbt" revision="1117893e2ec6b00c9fc3433e27062afd758e34d1" upstream="msm8930-kk-1-76-master"/>
  <project groups="broadcom_wlan" name="platform/hardware/broadcom/wlan" path="hardware/broadcom/wlan" revision="6e52db11b81648e47b205e3d6e51022ebea10fb4" upstream="msm8930-kk-1-76-master"/>
  <project groups="invensense" name="platform/hardware/invensense" path="hardware/invensense" revision="00c0bbda59ec2165ba0c4609ee0114691c92c698" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/hardware/libhardware" path="hardware/libhardware" revision="393ab89b46dcba3a2e25abbd8d8fff673e2b4d25" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/hardware/libhardware_legacy" path="hardware/libhardware_legacy" revision="8ff1c9d80a474ff8f981b38be9fbc8d4a81b457b" upstream="msm8930-kk-1-76-master"/>
  <project groups="default" name="platform/hardware/libsensors" path="hardware/libsensors" revision="06d3e2caf958fb8420891101ee701b934d5157cc" upstream="msm8930-kk-1-76-master"/>
  <project groups="qcom,default" name="platform/hardware/qcom/audio" path="hardware/qcom/audio" revision="999eb194b65f41e131a3a5c47135dd539fb15be8" upstream="msm8930-kk-1-76-master"/>
  <project groups="qcom,default" name="platform/hardware/qcom/bt" path="hardware/qcom/bt" revision="760ab2d607ebd10ed9f9b072759edf8c60644cd6" upstream="msm8930-kk-1-76-master"/>
  <project groups="qcom,default" name="platform/hardware/qcom/camera" path="hardware/qcom/camera" revision="560cf31e69fbc2c956a4162391d5447ab2b4d9d5" upstream="msm8930-kk-1-76-master"/>
  <project groups="qcom,default" name="platform/hardware/qcom/display" path="hardware/qcom/display" revision="ae90118f472959f2abb5996a6c04506fc3490ba8" upstream="msm8930-kk-1-76-master"/>
  <project groups="qcom,default" name="platform/hardware/qcom/gps" path="hardware/qcom/gps" revision="e23175b91bc095329dd010bf347f56ac679168a1" upstream="msm8930-kk-1-76-master"/>
  <project groups="qcom,default" name="platform/hardware/qcom/keymaster" path="hardware/qcom/keymaster" revision="c77e4652c7e56f559f6708fa5013d8d4d87bfd0c" upstream="msm8930-kk-1-76-master"/>
  <project groups="qcom,default" name="platform/hardware/qcom/media" path="hardware/qcom/media" revision="9ce3cab4952374eff8318db1ba0969d0bc3b1ef6" upstream="msm8930-kk-1-76-master"/>
  <project groups="qcom,default" name="platform/hardware/qcom/msm8960" path="hardware/qcom/msm8960" revision="7d28489ae38c0bed933fe1818fef587f0200dc53" upstream="msm8930-kk-1-76-master"/>
  <project groups="qcom,default" name="platform/hardware/qcom/sensors" path="hardware/qcom/sensors" revision="9a62292a7dd0cd83bf723f75a6b712178550f614" upstream="msm8930-kk-1-76-master"/>
  <project groups="qcom_wlan,default" name="platform/hardware/qcom/wlan" path="hardware/qcom/wlan" revision="950427841f1ce6452b9c74c7e3f006dcd770b6a4" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/hardware/ril" path="hardware/ril" revision="3c5defbb9c98ae0e9a35de88b377744df48b5da1" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/hardware/ti/omap3" path="hardware/ti/omap3" revision="3bbaa29066a684d01df42ddf0365266e59f2dc44" upstream="msm8930-kk-1-76-master"/>
  <project groups="omap4" name="platform/hardware/ti/omap4xxx" path="hardware/ti/omap4xxx" revision="bc1978cde1a8f61008ffdfe7a6d69037062ad6d8" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/hardware/ti/wlan" path="hardware/ti/wlan" revision="495914562a315a5152780709ab622cd987561de5" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/hardware/ti/wpan" path="hardware/ti/wpan" revision="9fc27663273414cee93f5219d48a28fe84b0bb7e" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/libcore" path="libcore" revision="eb840f71a6b5cfc34d302ac2bd7b616b5268216f" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk-java" name="platform/libnativehelper" path="libnativehelper" revision="e7f4e689e3e6195da47775f8384b8e70ca7646ac" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/ndk" path="ndk" revision="e58ef003be4306bb53a8c11331146f39e4eab31f" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/apps/BasicSmsReceiver" path="packages/apps/BasicSmsReceiver" revision="297d694657fde9521bbc245ab510fb45cc2e6879" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/apps/Bluetooth" path="packages/apps/Bluetooth" revision="3195781d77a1bf01f1ca7bb7c3c89373d74be978" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/apps/Browser" path="packages/apps/Browser" revision="17c251e2af40ff376a1902093c081d3d0afd250b" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/apps/Calculator" path="packages/apps/Calculator" revision="10c47bae9fa3b65c6a7fc33c2f4ed14b3e7eb86a" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/apps/Calendar" path="packages/apps/Calendar" revision="3ecb471da3db60a6a3026f387da05307b012d3fb" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/apps/Camera" path="packages/apps/Camera" revision="cbfc9d22ee4992e0472556f8958f40ef0ffcca87" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/apps/Camera2" path="packages/apps/Camera2" revision="d11555affcbac52493fa8646621f2de124328da2" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/apps/CertInstaller" path="packages/apps/CertInstaller" revision="c59c6aa02326a92051f37e4262fef258a0cef422" upstream="msm8930-kk-1-76-master"/>
  <project groups="default" name="platform/packages/apps/CmasApp" path="packages/apps/CmasApp" revision="8f9c4846bb78dc033d09f1b2a541d6b68e9e987f" upstream="kk-default-ccs"/>
  <project name="platform/packages/apps/Contacts" path="packages/apps/Contacts" revision="5a32ab353c29933a0fadfbaf7b51751f8c8f4dec" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/apps/ContactsCommon" path="packages/apps/ContactsCommon" revision="7159168e6e8ea4aa300b48aa1f6a74b5c16330c4" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/apps/DeskClock" path="packages/apps/DeskClock" revision="4fdecad3999906a0d168ca9ca8dfc194ba27446d" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/apps/Dialer" path="packages/apps/Dialer" revision="250b541a14518f0a7a7c8d2a4d01867e2b68d413" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/apps/Email" path="packages/apps/Email" revision="954eaf74bde1c4712d80719051bd318b0b0bfdca" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/apps/Exchange" path="packages/apps/Exchange" revision="1ca0db2479b27d931789ebf5bb10204249c72b99" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/apps/Gallery" path="packages/apps/Gallery" revision="2b2fc8808e6aebb4dcc45708d4a59ec69ccdab76" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/apps/Gallery2" path="packages/apps/Gallery2" revision="52b61624d43b6c03bb89b1ac3ba82fe18184f3eb" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/apps/HTMLViewer" path="packages/apps/HTMLViewer" revision="49b5e40da9f1277deaf1f1f5b1faf3bcf7edc07f" upstream="msm8930-kk-1-76-master"/>
  <project groups="default" name="platform/packages/apps/InCallUI" path="packages/apps/InCallUI" revision="7aee7cfbdd7ac109f2b48b3c8cf449b0dda093d9" upstream="8930KK-ccs"/>
  <project name="platform/packages/apps/KeyChain" path="packages/apps/KeyChain" revision="5623555d3340f654e3024341e5c2447f3e5b6300" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/apps/Launcher2" path="packages/apps/Launcher2" revision="465f7274f7cc81cddad36027bfca819aac7b1d66" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/apps/Launcher3" path="packages/apps/Launcher3" revision="a3ecdac3efc7b19a4e231d37af2d184bab7e9df9" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/apps/LegacyCamera" path="packages/apps/LegacyCamera" revision="bb749dad9bb03081ac9d46a7305a0541a95a4569" upstream="msm8930-kk-1-76-master"/>
  <project groups="default" name="platform/packages/apps/Mms" path="packages/apps/Mms" revision="0a1a4e893b061ddbb105a42372a756ef209020fa" upstream="8930KK-ccs"/>
  <project name="platform/packages/apps/Music" path="packages/apps/Music" revision="46ced81d98c4162b1ca8eb98488dcacc0571c7c3" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/apps/MusicFX" path="packages/apps/MusicFX" revision="4abe57bfef88fc79e14baf5168c5472043234a99" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/apps/Nfc" path="packages/apps/Nfc" revision="3101267f0ea14f44760437e29d8538f71c2e5fe4" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/apps/OneTimeInitializer" path="packages/apps/OneTimeInitializer" revision="01e429c08e51291315890de9677151a7e0b6ad35" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/apps/PackageInstaller" path="packages/apps/PackageInstaller" revision="af691250a0d3212d187fef67677fd5b719d13cdd" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/apps/Phone" path="packages/apps/Phone" revision="6e6ec387e07aa0b4cb53ec5b26f264e54aabbb12" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/apps/PhoneCommon" path="packages/apps/PhoneCommon" revision="162fb3bd5152665fe69de2ad06ab9f4a48c58979" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/apps/Protips" path="packages/apps/Protips" revision="e953b2f84febfbc415951e83ecff40d265deab81" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/apps/Provision" path="packages/apps/Provision" revision="78ca0db658fe6253d506916e36319e620476f809" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/apps/QuickSearchBox" path="packages/apps/QuickSearchBox" revision="558b710925cc47e1494facc9f4a0276b5d91d6f1" upstream="msm8930-kk-1-76-master"/>
  <project groups="default" name="platform/packages/apps/Settings" path="packages/apps/Settings" revision="31ca83f53ffbd4761893f51d0e4ae5e3067fcc26" upstream="kk-default-ccs"/>
  <project name="platform/packages/apps/SmartCardService" path="packages/apps/SmartCardService" revision="29eae320a4bd222b5ff1c092f84f1aebba88d0b7" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/apps/SoundRecorder" path="packages/apps/SoundRecorder" revision="272c588d2bda0364876e138b26295c604bdc199e" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/apps/SpareParts" path="packages/apps/SpareParts" revision="4db997871e3f4c3f84660815096e5276b47c5c91" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/apps/SpeechRecorder" path="packages/apps/SpeechRecorder" revision="536aa74ff3a77186bef29dc9333a34688fa59d13" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/apps/Stk" path="packages/apps/Stk" revision="32e420570a9cabb502c6ebc80f9162a17bdefcbc" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/apps/Tag" path="packages/apps/Tag" revision="752127478885a1aac667eeb2167b09b8301b2968" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/apps/UnifiedEmail" path="packages/apps/UnifiedEmail" revision="471bf332cd42715c9e5295864549e5915757b3d4" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/apps/VideoEditor" path="packages/apps/VideoEditor" revision="ced7873301a3fe0d141fe7317110b203284934c8" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/apps/VoiceDialer" path="packages/apps/VoiceDialer" revision="018c6d1ca8e967eeb2037ffa483c1bd2c4d93260" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/experimental" path="packages/experimental" revision="b834194c724c61a0b58ec6b014b4ade1adb7c406" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/inputmethods/LatinIME" path="packages/inputmethods/LatinIME" revision="d09b022c86827b50bb609d8574bcdd318346da68" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/inputmethods/OpenWnn" path="packages/inputmethods/OpenWnn" revision="32baa6febf996af5526e86d9ae38a958931640df" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/inputmethods/PinyinIME" path="packages/inputmethods/PinyinIME" revision="380313bf22aec37d32ea417483afb3ec91782b5f" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/providers/ApplicationsProvider" path="packages/providers/ApplicationsProvider" revision="3347f31bd268ca3153abe5def9361f625bd73efd" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/providers/CalendarProvider" path="packages/providers/CalendarProvider" revision="c5e5e58285f18415f4607c7027a338f4730d7114" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/providers/ContactsProvider" path="packages/providers/ContactsProvider" revision="b16c915561a807806da819cdf0852c84d9ff9296" upstream="msm8930-kk-1-76-master"/>
  <project groups="default" name="platform/packages/providers/MediaProvider" path="packages/providers/MediaProvider" revision="0d4f6423753796885ecebcc38e05c487902316f3" upstream="kk-default-ccs"/>
  <project name="platform/packages/providers/PartnerBookmarksProvider" path="packages/providers/PartnerBookmarksProvider" revision="96d0a80af45923767baf449fc8c735c2f71d64ae" upstream="msm8930-kk-1-76-master"/>
  <project groups="default" name="platform/packages/providers/TelephonyProvider" path="packages/providers/TelephonyProvider" revision="04d31d5c29c2cd6f7847dd7111e15dfd1afd3bc0" upstream="kk-default-ccs"/>
  <project name="platform/packages/providers/UserDictionaryProvider" path="packages/providers/UserDictionaryProvider" revision="361f35b7b1fe758d93e0952536a298b2ed045a89" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/screensavers/Basic" path="packages/screensavers/Basic" revision="6117c111d7e09c6fad2d84368c3dac9566b4923c" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/screensavers/PhotoTable" path="packages/screensavers/PhotoTable" revision="60a4c6434e8fa139d2599bc968ab211b4e29621a" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/screensavers/WebView" path="packages/screensavers/WebView" revision="6e0a80f6faed6191acc8ce1b6c79eada09e9e042" upstream="msm8930-kk-1-76-master"/>
  <project groups="default" name="platform/packages/services/Telephony" path="packages/services/Telephony" revision="d4b96d32715adf2bb7153842ca7291d44200bfde" upstream="8930KK-ccs"/>
  <project name="platform/packages/wallpapers/Basic" path="packages/wallpapers/Basic" revision="cedf04bc35a12396df158bb24e8300790332b29e" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/wallpapers/Galaxy4" path="packages/wallpapers/Galaxy4" revision="c2da10d8ae9b3a45f220069c60ec1ffd839ac1c7" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/wallpapers/HoloSpiral" path="packages/wallpapers/HoloSpiral" revision="c34113237e9d25244901bf7bd104099d948d4102" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/wallpapers/LivePicker" path="packages/wallpapers/LivePicker" revision="60e492da0bbebe716b1f99ca6a0fc13375e4abdf" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/wallpapers/MagicSmoke" path="packages/wallpapers/MagicSmoke" revision="5fb10178b0d92900cfaf4f21d7a52c63b4195d2e" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/wallpapers/MusicVisualization" path="packages/wallpapers/MusicVisualization" revision="0ac2ec30f455d352eecff7c27304fd3d1f1c96ad" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/wallpapers/NoiseField" path="packages/wallpapers/NoiseField" revision="53db91c32eda6a5c46b5070d2db256bfb7c47018" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/packages/wallpapers/PhaseBeam" path="packages/wallpapers/PhaseBeam" revision="d820f2943126c7155e164436a1f059f426cfc935" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/pdk" path="pdk" revision="3cd0f18e5adeb906d0bc827b98aa31726e302cc5" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk,darwin" name="platform/prebuilts/clang/darwin-x86/3.1" path="prebuilts/clang/darwin-x86/3.1" revision="426233405bef3c7c825095ab14256c3773894b9b" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk,darwin" name="platform/prebuilts/clang/darwin-x86/3.2" path="prebuilts/clang/darwin-x86/3.2" revision="af856d77b3cbb1f6afccdc531bee991403c28907" upstream="msm8930-kk-1-76-master"/>
  <project groups="darwin,arm" name="platform/prebuilts/clang/darwin-x86/arm/3.3" path="prebuilts/clang/darwin-x86/arm/3.3" revision="54acc51e28850485e380b55916868a4e1ff17998" upstream="msm8930-kk-1-76-master"/>
  <project groups="darwin" name="platform/prebuilts/clang/darwin-x86/host/3.3" path="prebuilts/clang/darwin-x86/host/3.3" revision="682de6b44a68579f40e39faf9766196158759154" upstream="msm8930-kk-1-76-master"/>
  <project groups="darwin,mips" name="platform/prebuilts/clang/darwin-x86/mips/3.3" path="prebuilts/clang/darwin-x86/mips/3.3" revision="da3dad928542362835082b2eda44e4dc315d65bb" upstream="msm8930-kk-1-76-master"/>
  <project groups="darwin,x86" name="platform/prebuilts/clang/darwin-x86/x86/3.3" path="prebuilts/clang/darwin-x86/x86/3.3" revision="f67a83f35e30f92b312fbee852184c3f6dc38f34" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk,linux" name="platform/prebuilts/clang/linux-x86/3.1" path="prebuilts/clang/linux-x86/3.1" revision="e95b4ce22c825da44d14299e1190ea39a5260bde" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk,linux" name="platform/prebuilts/clang/linux-x86/3.2" path="prebuilts/clang/linux-x86/3.2" revision="471afab478649078ad7c75ec6b252481a59e19b8" upstream="msm8930-kk-1-76-master"/>
  <project groups="linux,arm" name="platform/prebuilts/clang/linux-x86/arm/3.3" path="prebuilts/clang/linux-x86/arm/3.3" revision="2f6d2db9e2af3507d132cf5d286a42fe1d47f7bc" upstream="msm8930-kk-1-76-master"/>
  <project groups="linux" name="platform/prebuilts/clang/linux-x86/host/3.3" path="prebuilts/clang/linux-x86/host/3.3" revision="bba7eb9ee3ec2af12b926023256dbe4799995645" upstream="msm8930-kk-1-76-master"/>
  <project groups="linux,mips" name="platform/prebuilts/clang/linux-x86/mips/3.3" path="prebuilts/clang/linux-x86/mips/3.3" revision="51f8e2760628588fe268438d612d942c30d13fb2" upstream="msm8930-kk-1-76-master"/>
  <project groups="linux,x86" name="platform/prebuilts/clang/linux-x86/x86/3.3" path="prebuilts/clang/linux-x86/x86/3.3" revision="017a8a67f92a66b29ab17772e50642a7b9d0f8e6" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/prebuilts/devtools" path="prebuilts/devtools" revision="d0d6d09122bc496162dc66e952256d0e95db5208" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/prebuilts/eclipse" path="prebuilts/eclipse" revision="76f99d69c6843137da55d1a28c81920ac453ec15" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk,darwin,arm" name="platform/prebuilts/gcc/darwin-x86/arm/arm-eabi-4.6" path="prebuilts/gcc/darwin-x86/arm/arm-eabi-4.6" revision="21b2cba584638ed5ffad8e3fd3e6808bfa299cf0" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk,darwin,arm" name="platform/prebuilts/gcc/darwin-x86/arm/arm-eabi-4.7" path="prebuilts/gcc/darwin-x86/arm/arm-eabi-4.7" revision="26cb1865482ce3d9dd47ff5766180f3e7ade98ec" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk,darwin,arm" name="platform/prebuilts/gcc/darwin-x86/arm/arm-linux-androideabi-4.6" path="prebuilts/gcc/darwin-x86/arm/arm-linux-androideabi-4.6" revision="0f74cbc89b93c4db7fbf737f561cd69221f779a7" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk,darwin,arm" name="platform/prebuilts/gcc/darwin-x86/arm/arm-linux-androideabi-4.7" path="prebuilts/gcc/darwin-x86/arm/arm-linux-androideabi-4.7" revision="9a80d8ace620a6ba1396bfef04ff97c476a7f8ee" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk,darwin" name="platform/prebuilts/gcc/darwin-x86/host/headers" path="prebuilts/gcc/darwin-x86/host/headers" revision="4ac4f7cc41cf3c9e36fc3d6cf37fd1cfa9587a68" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk,darwin" name="platform/prebuilts/gcc/darwin-x86/host/i686-apple-darwin-4.2.1" path="prebuilts/gcc/darwin-x86/host/i686-apple-darwin-4.2.1" revision="2158dd34ce433fb8d79b5a1c340afac2cf00d5e8" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk,darwin,mips" name="platform/prebuilts/gcc/darwin-x86/mips/mipsel-linux-android-4.6" path="prebuilts/gcc/darwin-x86/mips/mipsel-linux-android-4.6" revision="837cdd9b3ac7231daaf961056c7505843130f667" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk,darwin,mips" name="platform/prebuilts/gcc/darwin-x86/mips/mipsel-linux-android-4.7" path="prebuilts/gcc/darwin-x86/mips/mipsel-linux-android-4.7" revision="23b86b6afa0287d2b45ba03ef347a6a6fcd104f3" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk,darwin,x86" name="platform/prebuilts/gcc/darwin-x86/x86/i686-linux-android-4.6" path="prebuilts/gcc/darwin-x86/x86/i686-linux-android-4.6" revision="042d6130038c95be86fcea5dddda2db07bd5aa27" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk,darwin,x86" name="platform/prebuilts/gcc/darwin-x86/x86/i686-linux-android-4.7" path="prebuilts/gcc/darwin-x86/x86/i686-linux-android-4.7" revision="b8d6b5d787751a78c0a1d38f209037a933b2371b" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk,darwin,x86" name="platform/prebuilts/gcc/darwin-x86/x86/x86_64-linux-android-4.7" path="prebuilts/gcc/darwin-x86/x86/x86_64-linux-android-4.7" revision="4ddebe05a38829b8630c9271019895ed68d78ec1" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk,linux,arm" name="platform/prebuilts/gcc/linux-x86/arm/arm-eabi-4.6" path="prebuilts/gcc/linux-x86/arm/arm-eabi-4.6" revision="d73a051b1fd1d98f5c2463354fb67898f0090bdb" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk,linux,arm" name="platform/prebuilts/gcc/linux-x86/arm/arm-eabi-4.7" path="prebuilts/gcc/linux-x86/arm/arm-eabi-4.7" revision="8b880805d454664b3eed11d0f053cdeafa1ff06e" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk,linux,arm" name="platform/prebuilts/gcc/linux-x86/arm/arm-linux-androideabi-4.6" path="prebuilts/gcc/linux-x86/arm/arm-linux-androideabi-4.6" revision="71c99ec3db1503a2124d5e287097d58b964deef7" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk,linux,arm" name="platform/prebuilts/gcc/linux-x86/arm/arm-linux-androideabi-4.7" path="prebuilts/gcc/linux-x86/arm/arm-linux-androideabi-4.7" revision="a1e239a0bb5cd1d69680bf1075883aa9a7bf2429" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk,linux" name="platform/prebuilts/gcc/linux-x86/host/i686-linux-glibc2.7-4.4.3" path="prebuilts/gcc/linux-x86/host/i686-linux-glibc2.7-4.4.3" revision="10191e2f442c5409cb70783508658d474612a97e" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk,linux" name="platform/prebuilts/gcc/linux-x86/host/i686-linux-glibc2.7-4.6" path="prebuilts/gcc/linux-x86/host/i686-linux-glibc2.7-4.6" revision="95bb5b66b3ec5769c3de8d3f25d681787418e7d2" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk,linux" name="platform/prebuilts/gcc/linux-x86/host/x86_64-linux-glibc2.7-4.6" path="prebuilts/gcc/linux-x86/host/x86_64-linux-glibc2.7-4.6" revision="ebdad82e61c16772f6cd47e9f11936bf6ebe9aa0" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk,linux,mips" name="platform/prebuilts/gcc/linux-x86/mips/mipsel-linux-android-4.6" path="prebuilts/gcc/linux-x86/mips/mipsel-linux-android-4.6" revision="90fc0bd53f2d07ef2383bfad53671f76801c740e" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk,linux,mips" name="platform/prebuilts/gcc/linux-x86/mips/mipsel-linux-android-4.7" path="prebuilts/gcc/linux-x86/mips/mipsel-linux-android-4.7" revision="e5c0976a142054784f7b695018448f7288c4fe58" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk,linux,x86" name="platform/prebuilts/gcc/linux-x86/x86/i686-linux-android-4.6" path="prebuilts/gcc/linux-x86/x86/i686-linux-android-4.6" revision="b9ebba077c2f62e930b16240d7f3ad61f1ad1dfc" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk,linux,x86" name="platform/prebuilts/gcc/linux-x86/x86/i686-linux-android-4.7" path="prebuilts/gcc/linux-x86/x86/i686-linux-android-4.7" revision="c7931763d41be602407ed9d71e2c0292c6597e00" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk,linux,x86" name="platform/prebuilts/gcc/linux-x86/x86/x86_64-linux-android-4.7" path="prebuilts/gcc/linux-x86/x86/x86_64-linux-android-4.7" revision="bbe08f8958377ba3a06f4081ed13b2399db448fb" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/prebuilts/gradle-plugin" path="prebuilts/gradle-plugin" revision="71348f05649f1658bcd323152da4534101949c81" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/prebuilts/maven_repo/android" path="prebuilts/maven_repo/android" revision="6fa1e00dc4b75eab6634cd1fd37b5797b86d2a0f" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/prebuilts/misc" path="prebuilts/misc" revision="e1720a1ffca8d85138891ab920a48965f66af560" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/prebuilts/ndk" path="prebuilts/ndk" revision="6643b81d18c5dcb2fec1c36ded7abe292127e045" upstream="msm8930-kk-1-76-master"/>
  <project groups="darwin" name="platform/prebuilts/python/darwin-x86/2.7.5" path="prebuilts/python/darwin-x86/2.7.5" revision="504e6fa059b0cd8809dc6afead97c699ff2289e2" upstream="msm8930-kk-1-76-master"/>
  <project groups="linux" name="platform/prebuilts/python/linux-x86/2.7.5" path="prebuilts/python/linux-x86/2.7.5" revision="f553427c6b5bb86e5b53c1cad1b6eaaca081b372" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/prebuilts/qemu-kernel" path="prebuilts/qemu-kernel" revision="21a68e06a104be3f98d776a5bb34ec98643c5bc9" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/prebuilts/runtime" path="prebuilts/runtime" revision="cf91192a5e0014fe7b98827abbf6daf9337c472e" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/prebuilts/sdk" path="prebuilts/sdk" revision="c234c025cca22439e633881a959d0d8921d00c06" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk,tools" name="platform/prebuilts/tools" path="prebuilts/tools" revision="5a48c04c4bb5f079bc757e29864a42427378e051" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/sdk" path="sdk" revision="86de8a911717ce2581b2b8eafd4ad3fd86577e08" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/system/core" path="system/core" revision="38afaae433c1c14e63d030d63041920ef84433a8" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/system/extras" path="system/extras" revision="8df354cbb1d20efc84c2023693b4e358bbd892a8" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/system/media" path="system/media" revision="97f372a6df7b7ff1f566d6906b891416a285b46a" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/system/netd" path="system/netd" revision="63fac0c0ab2be0021a6fb8d0cc2632534057b815" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/system/qcom" path="system/qcom" revision="cb573005708a58a1cdf1214bf8e7870c40b2c0bb" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/system/security" path="system/security" revision="ee8068b9e7bfb2770635062fc9c2035be2142bd8" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/system/vold" path="system/vold" revision="b139695f27a18f4186b3f9eece6e40a067c66704" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/tools/base" path="tools/base" revision="aca3dbe3fc617175bfb715bc573048ab2e14c18d" upstream="msm8930-kk-1-76-master"/>
  <project groups="tools" name="platform/tools/external/fat32lib" path="tools/external/fat32lib" revision="5b54b0e25a4b55fa6a180d225f8f1790fb63287b" upstream="msm8930-kk-1-76-master"/>
  <project groups="tools" name="platform/tools/external/gradle" path="tools/external/gradle" revision="8ff4a755637a21ac7b5918d86302e22ba3f7fa37" upstream="msm8930-kk-1-76-master"/>
  <project groups="pdk" name="platform/tools/swt" path="tools/swt" revision="fe30ee3a716015332e696d34d19bc27146a92cb6" upstream="msm8930-kk-1-76-master"/>
  <project groups="default" name="platform/vendor/dolby" path="vendor/dolby" revision="09888e3c649cec55f414313fcb1929db279fb165" upstream="8930KK-ccs"/>
  <project name="platform/vendor/qcom-opensource/bluetooth" path="vendor/qcom/opensource/bluetooth" revision="59e09278291730412aca4f68a05ed32fd44c08d7" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/vendor/qcom-opensource/fm" path="vendor/qcom/opensource/fm" revision="dd0196f7009ffb380128648feeb6a06e2e1474ee" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/vendor/qcom-opensource/kernel/kernel-tests" path="vendor/qcom/opensource/kernel-tests" revision="e7f774bef307a3a0b1781d1d7c579f8901899428" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/vendor/qcom-opensource/location" path="vendor/qcom/opensource/location" revision="5284b64113643182780db5172358953227b2b9a1" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/vendor/qcom-opensource/testframework" path="vendor/qcom/opensource/testframework" revision="e6396b107147fb4bb199e3dbfa880e262780dd6d" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/vendor/qcom-opensource/time-services" path="vendor/qcom/opensource/time-services" revision="15ddfdd8974a8529d1dd675289b11b006d7a4cc6" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/vendor/qcom-opensource/wlan/prima" path="vendor/qcom/opensource/wlan/prima" revision="b68c6653c9efed4a7a886f2ecd039fee470af2c4" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/vendor/qcom/msm8960" path="device/qcom/msm8960" revision="b22a6172c08d85d9adbaa826bbe8b57b994c511c" upstream="msm8930-kk-1-76-master"/>
  <project groups="default" name="platform/vendor/widevine" path="vendor/widevine" revision="fad4b75589d6e215194fd3561fab3203de119c5b" upstream="kk-default-ccs"/>
  <project name="platform/vendor/zte/coeus" path="device/zte/coeus" revision="06f24e395da52bba827f68daab7b9f831f70a31d" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/vendor/zte/nex" path="device/zte/nex" revision="79a2ce3db4b64feeda640a21c2695878b9d8ffab" upstream="msm8930-kk-1-76-master"/>
  <project groups="default" name="platform/vendor/zte/products" path="device/zte/products" revision="483f69813e0aceda98b88340e3460fa9019e4253" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/vendor/zte/rhea" path="device/zte/rhea" revision="a7f2ff140f575a4a9242be433bd54c2c23258f23" upstream="msm8930-kk-1-76-master"/>
  <project groups="default" name="platform/vendor/zte/ril" path="vendor/zte/ril" revision="4e177c2ebdecb6ec89a7a10a5f70573786f56131" upstream="8930KK-ccs"/>
  <project name="platform/vendor/zte/stormer" path="device/zte/stormer" revision="e5746fac6e7a4c340587b927c7fb72b833d21c9f" upstream="msm8930-kk-1-76-master"/>
  <project name="platform/vendor/zte/warplte" path="device/zte/warplte" revision="63dcc9915579462a51a3ce309122be166ef1c2e9" upstream="msm8930-kk-1-76-master"/>
  <project groups="default" name="zte/packages/zte/AAB" path="packages/zte/AAB" revision="42a2ede18a9897d9aeb76ab58f80852ecd112cda" upstream="P821A16"/>
  <project groups="default" name="zte/packages/zte/App_Common" path="packages/zte/App_Common" revision="d29f02673b7c9795888a5381eec1514e00feb4cf" upstream="8930KK-ccs"/>
  <project groups="default" name="zte/packages/zte/Browser" path="packages/zte/Browser" revision="10baf048b53fecd0a6a0dd1a046fc84ec3a30688" upstream="kk-default-ccs"/>
  <project groups="default" name="zte/packages/zte/Calculator_ZTE" path="packages/zte/Calculator_ZTE" revision="117bb2aa119af7d8deb339db952ce801f55b741e" upstream="kk-default-ccs"/>
  <project groups="default" name="zte/packages/zte/CameraZTE" path="packages/zte/CameraZTE" revision="e6b635e82e09a77c1bb7ddf82d1576610ac0125e" upstream="msm8930-kk-1-76-master"/>
  <project groups="default" name="zte/packages/zte/ContactsProvider_ZTE" path="packages/zte/ContactsProvider_ZTE" revision="57ed07f7180cb0e9fa91834561021bcb8497dc71" upstream="kk-default-ccs"/>
  <project groups="default" name="zte/packages/zte/Contacts_ZTE" path="packages/zte/Contacts_ZTE" revision="8bcca6a344e67f44cfa3ab26c68e95319490b389" upstream="kk-default-ccs"/>
  <project groups="default" name="zte/packages/zte/DLNA" path="packages/zte/DLNA" revision="1c09ca0f829f5b1982a6c4c5272947516b0303e1" upstream="msm8930-kk-1-76-master"/>
  <project groups="default" name="zte/packages/zte/Dialer_ZTE" path="packages/zte/Dialer_ZTE" revision="97b7079f421d134801267d3163c6ffc028d5c6ea" upstream="kk-default-ccs"/>
  <project groups="default" name="zte/packages/zte/DolbySettings" path="packages/zte/DolbySettings" revision="3d32d646946f731bbcd0bf51663ecb32dc8f8ae7" upstream="8930KK-ccs"/>
  <project groups="default" name="zte/packages/zte/DownloadProvider" path="packages/zte/DownloadProvider" revision="34ebfb83994fe80177cb4c96339bc2d2b3eac7fe" upstream="kk-default-ccs"/>
  <project groups="default" name="zte/packages/zte/Email" path="packages/zte/Email" revision="01f1e88ee25797f03744970e883933b6ad76ccb1" upstream="8930KK-ccs"/>
  <project groups="default" name="zte/packages/zte/Emode" path="packages/zte/Emode" revision="e181460b79618405cde753cf4fbeff6c2b0534d9" upstream="default-ccs"/>
  <project groups="default" name="zte/packages/zte/EncryptLogcat" path="packages/zte/EncryptLogcat" revision="db5814b97d4c0bebb97fe7e3b16bd56fbc0f29d0" upstream="default-ccs"/>
  <project groups="default" name="zte/packages/zte/Filer" path="packages/zte/Filer" revision="6f19db462b98df1b32df52472307a4ef9cf3de4f" upstream="kk-default-ccs"/>
  <project groups="default" name="zte/packages/zte/FlashLight" path="packages/zte/FlashLight" revision="062b7952518d2036971d63d20b92f64545b9abbb" upstream="kk-default-ccs"/>
  <project groups="default" name="zte/packages/zte/FmRadio" path="packages/zte/FmRadio" revision="2e37712a25e1a11ec2f910fa1ff84a1805b6941e" upstream="kk-default-ccs"/>
  <project groups="default" name="zte/packages/zte/GalleryZTE" path="packages/zte/GalleryZTE" revision="f9bd1ebee08409a5a21e01f2ab0e7801b90e343f" upstream="msm8930-kk-1-76-master"/>
  <project groups="default" name="zte/packages/zte/LockScreen_ZTE" path="packages/zte/LockScreen_ZTE" revision="3a5a94fe6690eb3de5a0141c0afc245ec1f6bb82" upstream="kk-default-ccs"/>
  <project groups="default" name="zte/packages/zte/MiniAnyLongPressKeyguard" path="packages/zte/MiniAnyLongPressKeyguard" revision="7df6aba1f02f60ca90077ecee3ac00b49f918e39" upstream="kk-default-ccs"/>
  <project groups="default" name="zte/packages/zte/MusicPlayer" path="packages/zte/MusicPlayer" revision="f097b94f05ca4312e52d438688a52ee04c63359e" upstream="kk-default-ccs"/>
  <project groups="default" name="zte/packages/zte/OmaDM" path="packages/zte/OmaDM" revision="0dfd40102de282680ffb15f45225e2eca01c3a9a" upstream="P893A21"/>
  <project groups="default" name="zte/packages/zte/PhotoEditor" path="packages/zte/PhotoEditor" revision="fe6bf0b0aaea048ac6a55f646169d212c72b8615" upstream="kk-default-ccs"/>
  <project groups="default" name="zte/packages/zte/SoundRecorder_ZTE" path="packages/zte/SoundRecorder_ZTE" revision="095776d833f1d76d936125b9d545726138b66b2b" upstream="kk-default-ccs"/>
  <project groups="default" name="zte/packages/zte/SrsSetting" path="packages/zte/SrsSetting" revision="7342d0023b92e2675eaa62bbd755731faa447645" upstream="8930KK-ccs"/>
  <project groups="default" name="zte/packages/zte/TaskManager" path="packages/zte/TaskManager" revision="2be3763d56d944b2bd43c507734e8d335aff4735" upstream="kk-default-ccs"/>
  <project groups="default" name="zte/packages/zte/Timer" path="packages/zte/Timer" revision="d2ef05d0c6660453317aaaf00be0fbe2e389a25e" upstream="8930KK-ccs"/>
  <project groups="default" name="zte/packages/zte/VideoPlayer" path="packages/zte/VideoPlayer" revision="ecea6d0739550462561a8d8169d62034b6863ca9" upstream="kk-default-ccs"/>
  <project groups="default" name="zte/packages/zte/WiFiShare" path="packages/zte/WiFiShare" revision="c130c66ea1f8bb3b1586dc4234e3d4ef6038949d" upstream="msm8930-kk-1-76-master"/>
  <project groups="default" name="zte/packages/zte/WorldTime" path="packages/zte/WorldTime" revision="37bd053a10ffdf77c6cec1c9d05073a65159ec16" upstream="8930KK-ccs"/>
  <project groups="default" name="zte/packages/zte/ZteSettingsPatch" path="packages/zte/ZteSettingsPatch" revision="1d72d7f809a2decb541a3e13a7dc9b3c564d46f8" upstream="kk-default-ccs"/>
  <project groups="default" name="zte/packages/zte/alarming" path="packages/zte/alarming" revision="b4940f3b0191a7ae54100bce455d19713a9022a3" upstream="kk-default-ccs"/>
  <project groups="default" name="zte/packages/zte/backup" path="packages/zte/backup" revision="2761f208a0db18d09cb0bb672d7a8611e0c4ebf8" upstream="kk-default-ccs"/>
  <project groups="default" name="zte/packages/zte/zdm" path="packages/zte/zdm" revision="e0c22b912b9822b2c44089e1c1074215b8fb94d5" upstream="kk-default-ccs"/>
  <project groups="default" name="zte/vendor/google" path="vendor/google" revision="423eac3a3314a98553a8f50445c380e7fc5bd61f" upstream="kk-default-ccs_P893A21"/>
  <project groups="default" name="zte/vendor/pcsuite" path="vendor/pcsuite" revision="952fab1a5ffe5af8753922fefd60c3b63b462232" upstream="default-ccs"/>
  <project groups="default" name="zte/vendor/zte/AssistantApp" path="vendor/zte/AssistantApp" revision="4836a28406cfd476c12e2cb915de53edab54fd0f" upstream="default-ccs"/>
  <project groups="default" name="zte/vendor/zte/ChameleonProvider" path="vendor/zte/ChameleonProvider" revision="e3f4cc60e4c28d0e23b1b8c5f932e447d95247cc" upstream="kk-default-ccs"/>
  <project groups="default" name="zte/vendor/zte/FieldTestTool" path="vendor/zte/FieldTestTool" revision="c2a1dd8f118182a61945a413fd80f70e8b43f835" upstream="default-ccs"/>
  <project groups="default" name="zte/vendor/zte/SdlogApp" path="vendor/zte/SdlogApp" revision="58d6457d4c0ec0531371a4b9d17d1cd633fa4311" upstream="default-ccs"/>
  <project groups="default" name="zte/vendor/zte/SprintExtension" path="vendor/zte/SprintExtension" revision="42714581408e39e01b913bba31df2188e212ac31" upstream="kk-default-ccs"/>
  <project groups="default" name="zte/vendor/zte/akmd8962_new" path="vendor/zte/akmd8962_new" revision="a0c9206c87026290c3eefbc532f4487fa08e930d" upstream="msm8930-kk-1-76-master"/>
  <project groups="default" name="zte/vendor/zte/akmd8963" path="vendor/zte/akmd8963" revision="1642428437681c0c87fd7b2347f25d2b40e581fe" upstream="8930KK-ccs"/>
  <project groups="default" name="zte/vendor/zte/amss-debug" path="vendor/zte/amss-debug" revision="20f283628e35591732e4196228dc9cf48ee06e9a" upstream="default-ccs"/>
  <project groups="default" name="zte/vendor/zte/assistant" path="vendor/zte/assistant" revision="996a5264f3a24b3160e30cdcad86aecde5b51cc5" upstream="default-ccs"/>
  <project groups="default" name="zte/vendor/zte/bt_testmode" path="vendor/zte/bt_testmode" revision="962fdebd7254bac4c5283cf7d79d89a1cea8e933" upstream="kk-default-ccs"/>
  <project groups="default" name="zte/vendor/zte/buildota" path="vendor/zte/buildota" revision="d8d2a55fcfe1344ce8b050b73788f1ef84f2c10b" upstream="msm8930-kk-1-76-master"/>
  <project groups="default" name="zte/vendor/zte/checkdata" path="vendor/zte/checkdata" revision="83a10d53b62860030e9ba4888041fede0de31bc6" upstream="kk-default-ccs"/>
  <project groups="default" name="zte/vendor/zte/fastmmi" path="vendor/zte/fastmmi" revision="0eacd0cb02fa246dd51e8e70d3371a70e8361e05" upstream="8930KK-ccs"/>
  <project groups="default" name="zte/vendor/zte/imagelib" path="vendor/zte/imagelib" revision="717414e8b889fd0250f64e08faf6f592d093fdda" upstream="msm8930-kk-1-76-master"/>
  <project groups="default" name="zte/vendor/zte/iw" path="vendor/zte/iw" revision="ce01db17a22674a33824022bde948f453345b986" upstream="kk-default-ccs"/>
  <project groups="default" name="zte/vendor/zte/modem_api" path="vendor/zte/modem_api" revision="c1884ec906d15ef53d43384ed82f2130292b6f1e" upstream="default-ccs"/>
  <project groups="default" name="zte/vendor/zte/modemservice" path="vendor/zte/modemservice" revision="9fe05bfd63a925da84e1a4e70cf73ca3ff26a7bf" upstream="default-ccs"/>
  <project groups="default" name="zte/vendor/zte/nfc" path="vendor/zte/nfc" revision="dbda7d975b9978eb4a4ba6c9c4affcbbfa914f7e" upstream="kk-default-ccs"/>
  <project groups="default" name="zte/vendor/zte/proximity_init" path="vendor/zte/proximity_init" revision="2b99c6a3a92119b9a916b3f1877139eb796240c8" upstream="msm8930-kk-1-76-master"/>
  <project groups="default" name="zte/vendor/zte/sdlog" path="vendor/zte/sdlog" revision="fc4fa22bb254d4b743be7f71ffd70c3a3e4352fb" upstream="default-ccs"/>
  <project groups="default" name="zte/vendor/zte/sensor_test" path="vendor/zte/sensor_test" revision="1765b7f11fa1c2558b6ab482281303cb7c8490fe" upstream="msm8930-kk-1-76-master"/>
  <project groups="default" name="zte/vendor/zte/trigger_modemload" path="vendor/zte/trigger_modemload" revision="542bf2b27794ec4ee304c058de0c51866d3eb47f" upstream="default-ccs"/>
  <project groups="default" name="zte/vendor/zte/usbscript" path="vendor/zte/usbscript" revision="a0318b833f82cff42d9245db9317bac990f525b9" upstream="kk-default-ccs"/>
  <project groups="default" name="zte/vendor/zte/wcn_fcctest" path="vendor/zte/wcn_fcctest" revision="26fc6b11f4c7c74012d391f099122a8abbecd1d0" upstream="kk-default-ccs"/>
  <project groups="default" name="zte/vendor/zte/wcn_ftm" path="vendor/zte/wcn_ftm" revision="7539ff9e858b53f32dedbcacd90ca9c5e659287c" upstream="kk-default-ccs"/>
  <project groups="default" name="zte/vendor/zte/zte_emode" path="vendor/zte/zte_emode" revision="a8eeda62e7692e0fc071deae0f27ed3e9da51be1" upstream="default-ccs"/>
  <project groups="default" name="zte/vendor/zte/zte_ext4util" path="vendor/zte/zte_ext4util" revision="06f8a68ada1d29b6a549b9d21cd35002f0e95697" upstream="kk-default-ccs"/>
  <project groups="default" name="zte/vendor/zte/zte_fixebr" path="vendor/zte/zte_fixebr" revision="2de1c1115cfd99136f469ded8bb04bc2179f3dd4" upstream="kk-default-ccs"/>
  <project groups="default" name="zte/vendor/zte/zte_format_vfat" path="vendor/zte/zte_format_vfat" revision="2265d7b3ee6676dfaef9708f9fa5a5feaf4b579d" upstream="kk-default-ccs"/>
  <project groups="default" name="zte/vendor/zte/zte_ftmd" path="vendor/zte/zte_ftmd" revision="6bf05c3fa836a6a9792504d9c13211a31f221a69" upstream="msm8930-kk-1-76-master"/>
  <project groups="default" name="zte/vendor/zte/zte_log" path="vendor/zte/zte_log" revision="953ac8f0f9b7eb92bf5c30b107db07e6f9c4316b" upstream="default-ccs"/>
  <project groups="default" name="zte/vendor/zte/zte_root" path="vendor/zte/zte_root" revision="971dd3c27d5e15ac90be11c8a05f634a5856568a" upstream="default-ccs"/>
  <project groups="default" name="zte/vendor/zte/zte_vfat_check" path="vendor/zte/zte_vfat_check" revision="18a68492d1e562a63e3470c64ff7a8b788c22897" upstream="kk-default-ccs"/>
  <project groups="default" name="zte/vendor/zte/ztediag" path="vendor/zte/ztediag" revision="83f846d2f6406fa8ccaddce520e79aa9989fc972" upstream="kk-default-ccs"/>
  <project groups="default" name="zte/vendor/zte/zteservice" path="vendor/zte/zteservice" revision="9054414228eca84808ac22f0f356998f466eb147" upstream="default-ccs"/>
  <project groups="default" name="zte/zte_config" path="zte_config" revision="171185316f6405a81cfeebd5cc4dddc52ebfe802" upstream="kk-default-ccs">
    <copyfile dest="build.sh" src="build.sh"/>
    <copyfile dest="buildspec.sh" src="buildspec.sh"/>
    <copyfile dest="create_splash.sh" src="create_splash.sh"/>
    <copyfile dest="findelf.sh" src="findelf.sh"/>
    <copyfile dest="cert.sh" src="cert.sh"/>
    <copyfile dest=".repo/repo/subcmds/lamp.py" src="toolkit/lamp.py"/>
  </project>
  <project groups="default" name="zte_custom_data" revision="f3a330ea5705d8361c77a2c393ea23ec70a4cfd7" upstream="kk-default-ccs"/>
  <project groups="default" name="zte_overlays" revision="b1996fcbd830f9997502506bfedb2e0ffea96066" upstream="kk-default-ccs"/>
  <project groups="default" name="zte_security" revision="df9e8eed7e9450608c1e4b620b85a515464f8a68" upstream="default-ccs"/>
</manifest>
this is how you would strip the module
arm-eabi-4.4.3/bin/arm-eabi-strip --strip-unneeded wlan.ko
that will shrink it down a lot
here is a little something I made and you should be able to use it with your phone with some slight changes
it will build a zImage from kernel source
pack the zImamge and ramdisk into a boot.img
strip the modules for you
make a flashable zip that installs the modules and new boot.img
just take a look at the makez740krnl.pl and you will see what it does
https://www.mediafire.com/?undefined
thanks, thanks, thanks!!!
i just use the img toolkit to unpack and repack. the z998 doesn't have a dtb.img or anything so it's not too complicated.
i might start using this though on occasion.
so stripping the module will do what exactly??? just decrease the size of it?
also, why will this kernel not work for kk?
both jb and kk on the z998 use the 3.4 kernel, so what would change to prevent it from working??? i have tried my kernel in cm11 and it doesn't boot but i haven't figured out why though.
(my goal is to build cm11 for the device i was just starting with jb since that's what the phone came with originally)
do you think your kernel will work for the z998 (msm8960 variant) for cm11? i wouldn't really know where to begin with the config though because zte did not enable config access in /proc for their kk kernel and i assume there are a few changes from the jb config.
sorry for all the questions... compiling kk and beyond has gotten extremely complicated, almost too much for me to deal with really. the learning curve from previous versions is ridiculous...
stripping the kernel removes debug symbols and such, and should get the size down to 2mb
3.4 kernel means nothing, what matters is what ION version and adreno drivers the kernel has in them, and that stuff is not so easy to upgrade, especially ION because the video sound, media, camera and such use it
my cm11 kernel has adreno 3.0 or something like that but it is the KK version
I have a multi phone ROM that I put out that would probably boot your phone with CM11
http://androidforums.com/threads/cm11-developer-and-tester-thread-for-zte-msm-8x30-devices.834705/
the problem I ran into was getting the camera libraries to work with my KK specialized kernel, so I kind of threw in the towel, well that was one of the reasons, dont want to talk about the others
what you may want to look at is the CM11 for the ZTE AWE, phoenum put out a cm11 rom that used a JB kernel, slightly modified by him, and he was able to get the camera partially working
Does you phone have Offical KitKat Rom, if so, does it have the KK kernel source ?
i was thinking it must be either gpu related or selinux related as a guess.
i am VERY familiar with trying to upstream port/backport msm gpu and adreno drivers. it's hard to do mainly because others' commits in github are not always complete or accurate or build with particular toolchains or require different werror wno-error make configurations which sometimes end in a broken zImage and psuedo kernel driver ports that never work right.
this is where i started initially https://github.com/hroark13/zte_msm8x30_cm11
which is your work.
is this for the zte radiant 8x30 hdpi variant?
i realized immediately though that you were using different qcom adreno libs than my stock device.
i've since gone another way using the qcom msm8960 caf device trees which has become a PIA and requires a ton of minor changes to work with the cm11 kk repo which is a janky way of building.
yes there is a private zte kernel source not released but given in the zte official kk update--it is the long code above which is zte's private manifest for their complete kk tree for the z998. first time i've seen zte do such a thing. i tried to download but it wouldn't authenticate me as a downloader...
<project name="kernel/msm" path="kernel" revision="ffb6bfc0de28089270158275a6ec231b0876d4f7" upstream="msm8930-kk-1-76-master"/>
i have not found a working kernel source from zte bulletins yet... i think the one i'm using for jb is based on a samsung msm8960 kernel source. can't really remember but it's not my work. it just happened to build perfectly with 4.6 (and the device proc/config.gz) which is what i assumed is what zte used to build the official kernels.
i'm anxious to see if my current build completes and boots. if so i'll update the github repo for it. using the stock zImage though...
i really appreciate the help/advice.
my current build has gone smoothly thus far not using caf qcom hardware display and media trees.
my problem could be from insisting on using the 8960 (like similar htc and samsung devices) configuration instead of that for the 8930. idk
your rom boots but shows nothing but lines and colors... then black. touch responds and audio works when i touch the screen.
i might try working from your tree again i guess... my build completed but still didn't boot. kernel fail again...
you should take my rom, and use my kernel source and build a new kernel for your model, but verify that the right LCD is selected in the kernel config
i'm working on something now. the major differences between your coeus config and the stock jb z998 config are the camera sensor drivers, and the lack of a lcd driver defined on the but instead read from i2c chip natively through a generic kernel device.
i'm going to merge my commits into the fork i made of your repo to get booting on z998 as well as other changes to get the camera working, audio, and whatever else i find not working. audio crashed the device hard, but the initial config changes i made made your kernel source work.
nice work dude. trust me, i appreciate all the time you put in to create cm11 for these common devices.
this doesn't work btw.
the devices are too unalike...
your kernel source is working for my needs now though. thanks again
for whatever reason i'm having crap tons of problems using any display and media version in the 4.4.4 cm11 repo... driving me crazy.
i had one device tree that was building perfectly but not booting because of the kernel before i started anew and i have deleted it by accident. now i'm starting from scratch again and can't remember what i did to get gralloc, copybit, and hwcomposer to compile without errors.
ugh. it's killing me i can't get this going.
