My ZTE Zmax Pro keeps saying, 'Android is optimizing, optimizing app 1 of 1' during every boot. When I first got the phone, it didn't do this. I don't know what is wrong with it. Help is greatly appreciated. Thank you.
It is usually rebuilding the ANT cache or something like that. Sounds like an app, or it's cache is messed up.That "Android it optimizing" message is when the OS has updated or changed and the apps need to be recompiled for the runtime environment. Before you reset, you might try booting into recovery and clearing the system cache partition.
If that doesn't work, then I guess a reset is in order.
That 'Android it optimizing' message is when the OS has updated or changed and the apps need to be recompiled for the runtime environment. Before you reset, you might try booting into recovery and clearing the system cache partition.
I an having same problems as reported above and have done all suggestions above and still behaving same. Sometimes it takes an hour just to boot up.
Yeah before my phone had this optimization problem, my phone was hot but it would get hot easily from charging it for just 5 minutes, and I don't use my phone when it's charging.Happened to me on Monday after i left my phone out in the sun for audio recording. It shut off on its own due to overheating and took forever to boot up due to throttling(stuck on optimizing).
TL/DR Keep your phone cool...
I registered just to thank you for having the right answer for me.To all of you. My husband and I just had this problem with both of our ZTE Max ..he saw somewhere on a thread on some other site to delete Zedge..
Uninstalled Zedge and still have the problems. 😐To all of you. My husband and I just had this problem with both of our ZTE Max ..he saw somewhere on a thread on some other site to delete Zedge..they said since the new Zedge update a week or so ago they've all had this problem with nothing fixing it untill now. We both deleted Zedge immediately,rebooted and sure enough..it booted up nice and fast. I don't know if this will fix all of you but it worked for us tonight . Things seem to load fast as well. Good luck.
To all of you. My husband and I just had this problem with both of our ZTE Max ..he saw somewhere on a thread on some other site to delete Zedge..they said since the new Zedge update a week or so ago they've all had this problem with nothing fixing it untill now. We both deleted Zedge immediately,rebooted and sure enough..it booted up nice and fast. I don't know if this will fix all of you but it worked for us tonight . Things seem to load fast as well. Good luck!
Thank you... This fixed my restart issue!
Look into the ZTE Ban from the Trump administrationI don't have Zedge on my phone. It could be another app doing it or its a bad update. When I first noticed it was doing it, it listed that it was optimizing 7 apps. Now after a few restarts, its down to optimizing 1 app for a solid 15 minutes at boot. Then when it does boot, it runs iffy and android crashes alot. I think the (app) it keeps trying to optimize at start is the Android OS or something with ZTE. I'm running Android 6.0.1 and system update Z981 V1.0.0B14. When I tell it to update it says everything is current. Pretty frustrating. I really like this phone and its turning into a turd. Going to start uninstalling stuff to see if its a bad app, but I think its the newest ZTE update doing it.
The only drawback is the phone still does the 15 minute "app optimization" at boot and all of my icons on the home screen were deleted. I had to rearrange them back the way I had them.
