Root ZTERoot Utility for Linux and Cygwin
Earthnfire78
Hello I'm a Optimus V ROM Developer from AndroidCenteral, have a few post on this website but do not come here much. A friend of mine has this phone and asked me if I can do anything with it, so I've add this phone to my development table.
I took the Rooting Utility for Windows CMD and adapted it for use in Linux (Mostly do to the fact I hate Windows CMD and I'm a Linux user as I build ROM's for the Optimus V from source.
One of the things you well notices is I moved some of the files around placing them in the folders that they should go into.
Download here and unzip the file: and read the READ.md text file for instructions.
Using Terminal
Code:
$ cd ZTERoot
Next run the shell script (NOTE: You may need to run this up to three times and phone well reboot with each attempt).
Code:
./ZTERoot.sh
The root if successful can be checked with the Terminal Emulator by checking for the "# " symbol and the Superuser app well ask you to allow Terminal superuser access after enter the "su" command.
I well be updating this in a few days to also include flashing a custom recovery image, and well have a menu setup as well for easier use.
Operating System Linux is not support!
is the error i get after step 2
any ideas ,
Glad there is another windowzzz hater on here :-0
Sorry for the lateness, because I don't have this phone keeping up with development is hard, but I have updated and fixed the errors people were getting.
