Help ¿ White Blinking Light at Bottom of Nexus5 ?
bob12603
What's it trying to tell me? I haven't figured it out.
Also, is there no low battery alert? Sometimes I forget to charge the phone and the battery gets so low I have to charge it before it will turn on. My old HTC/Windows phone would blink a light and beep to let me know that the battery was low.
Thanks, Bob
I would assume it's notifying you of unread email or SMS, or missed calls - basically a notification that you've not looked at. I don't have an N5, so can't check for a relation between colour of light and what sort of notification, but I'm pretty sure that's what it means.
For a low battery alert go to: Settings > Battery > Menu (3 dots upper right corner) > Battery saver. You will probably want to leave it in the 'Off' position. Otherwise the battery saver runs all the time. Instead, tap on 'Turn on automatically' and select at 5% or 15% battery as desired. You will get a low battery alert you can't miss.
