redheadedguy
Member
found this early this morning. IT WORKED! installed voodoo ota and updated. waiting to see if it holds.
ONE CLICK Downgrade, using Wolf's method and root tool (thanks to viperboy)
I modded ViperMods awesome prime tool, to add an option to one click downgrade, using wolf's no root method . Just put the blob of FW you want to go to on the root of your primes internal memory, then run option 1 on my modded vipermods tool
99.9% credit go to -Viperboy- and Wolf849 i just added option in viperMOD's tool
EDIT: Fixed error in script
Download:
https://docs.google.com/uc?id=0B8gHy...xport=download
viperMOD Primer Tool v4.5 - Modded by bpear_v3.zip
Dev-Host - The Ultimate Free File Hosting / File Sharing Service
*NOTE* this is using Wolf's method 2 which is confirmed to work on prime, im not sure about tf101 etc. from here http://forum.xda-developers.com/show....php?t=1622628
Mirrors of WW and US .15 blob: you have to extract the .zip, possibly twice, then there will be a blob file, put that on /sdcard
http://forum.xda-developers.com/show...0&postcount=47
Download:
