Help 1 very basic Q if you please :)
emily01
Hey all ,
how do u set the x10 to ring for the maximum length of time ?
i use ringdroid and although the sound clip i made rings for long enough when i test it, when the phone actually rings with a call it its no where near as long as the clip i made .. or long enough for me to answer the damn thing ! lol
thanks in advance , em
AFAIK, it should play for as long as the phone is ringing, and I think it loops if the clip is too short. Maybe it's getting cut off by your voice mail? Maybe you can set it to pick up after a larger number of rings?
Also, make sure that there's no silence at the beginning of the ringtone.
I don't know which company you are with, but with Rogers (Canada) they let your phone ring for a maximum amount before it goes to voicemail that you cannot control. with my regular ring it was 4 rings and then voicemail.
try calling your provider and asking them if that is the case.
hey guys ,
thanks for the replies ...
Grospolina , nope no silences at the beginning of ringtone and yes its defiantly being cut off by my voicemail , but i can see no way of changing how long my phone rings for .
Jack Frost ...im with tmobile in the uk and have been for years ....never had this problem with my other phones... in fact i remember as far back as my motorola razer i could set the ring length lol
