10 Battery Saving Tricks
Blackout720
Some will say the battery is good others will say it sucks. I have hear them both for the Galaxy S6 so here is a few tips for increasing the battery life on your device. This works for any Android device.
1- Avoid Live wallpapers, instead set Dark wallpapers.
2- Set Brightness to " Auto " and lower Timeout Duration
3- Delete unused widgets
4- Toggle From 4G to 2G
5- Changing Application Sync Settings
6- Disabling Background Data
7- Close applications that you are not using
8- Turn off WiFi & Bluetooth when not needed
9- Disable unnecessary features & gestures
10- Enable power saver (Duh)
Here is a video guide on how to access and use these features on your phone if you dont happen to know how to.
