persistentone
Who makes a good Android tablet with 10-inch-or-larger screen and running Android 7 or later? Ideally, I would like the price to be under $300.
Based on one day of research, Galaxy Tab A does look like a great call. The Samsung Galaxy Tab A SM-T580 is an "international" version with 10.1 screen and 32 GB of memory, and the price is around $210. The negative reviews suggest some of these units die within the first year, and a few are complaining about Chinese language or other foreign language pre-configured on the device. Most of the reviews suggest it would be UK English, which would be easy to reconfigure.
What do you guys think of this unit?
Grey imports. From Hong Kong most likely. They wouldn't be covered by Samsung warranty, and that would need to be provided by the vendor or Amazon.
can you be more specific? what device did you get?I got one $110,Android 9.0 Pie
I got it on Amazon. Called Matrixpad Z4 tabletcan you be more specific? what device did you get?
