Help 10 Viking Pro Android Tablet won't update
I keep getting this device not compatible with apps I already had like Starbucks, or The Seattle Seahawks app. How or can this be fixed??? Or am I stuck with an outdated system for a tablet just bought from Wal-Mart?
Hi Suzanne, and welcome to Android Forums!
When you say the apps aren't compatible, what is your tablet telling you? It's running Android 5.0, so it should be able to handle the apps.
That's really weird. I would suggest that you make sure that Google Play Services is updated to the latest version, as well as the Play Store. I know that some apps are optimized for smartphones and won't work on tablets. You might verify tablet compatibility with the app developers.
I will look into Google play services for update thank you.
Everything should update automatically once you connect to WiFi. There's a site called APK Mirror where you can download updates to apps, but you really shouldn't have to do that much work...
