Help 100% CPU, Phone's very laggy!?
SystemPanel Lite is telling me CPU's at 100%. My phone has been very laggy this week. But my battery is amazing and I can get about a good 10 - 12 hours before I have to charge it. I don't know what's going on? I've tried deleting apps but it's still so laggy.
CPU always running it at 100%? thats crazy. Go check your system resource for what service is using memory/cpu. If its some BS app then disable it from boot and shut it off if it restarts. If you kill the task then it would just restarts again so your best bet is to disable the service and keep it off. Then reboot and see as it should fix it, as sometime some app has memory leaks which never release the resource when allocated as only way to reallocate them is to manually do it or easy methods for you would be to restart it.
The 100CPU util is a known bug. Its easily solved by turning on the USB debugging; MENU > Settings > Applications > Development, then enable USB debugging.
