128GB MicroSD card?
Azure_
Does the Volt 2 support MicroSDXC? If so, then I could use a 128 microSD card. I see that the original volt does, but I don't know about the Volt 2.
Got the phone and confirmed that it does indeed work fine with a 128GB microSD card, so likely any microSDXC card will work.
