Just remember that any return grace period in software retail is the exception, rather than the norm.
I'd be OK with an hour, I'd also be OK with none. 24 hours was a bit long though.
True, apple has no refund policy nor does amazon. The problem with any refund policy is someone can download the app, back it up, refund, and reinstall the backup. Even with the 15 min policy most apps can have this done to them unless the dev puts in a market check to confirm the app is listed as purchased. Until Google does something to prevent this it will be hard to draw some developers to Android and away from google.
That's interesting. You know I hadn't really thought about that when wondering why my cancellation rates were higher with my paid app rather than the donate one. (some of that is of course normal, donations are rarely cancelled and I see 5-8% cancells from the pay app).
I hate to do it, but I think I'm going to have to implement some sort of very light (policy wise) DRM using Google's LVL DRM. I've been trying to hold back, but the number of pirated copies is getting out of hand.
I suggest adding DRM to all paid apps, I think it may require additional permissions...full internet access I think...but it prevents people from pirating your app some what. There are people out there who will crack the app and post it on warez sites but the DRM will prevent some piracy as some people would not use a warez site but would be willing to backup and refund also some carriers block sideloading.
The amazon app store allows you to simulate the app on your PC.
That might help some people too.
I would rather they extend it to 1 hour than go back to the 24 hour period. 15 mins is enough to check some thing but not everything. To the OP, now that you have it purchased when you upgrade your phone or change your rom you can try it again and won't have to pay for it.
I agree that 15 minutes is a joke. Supposedly people were abusing the 24 hour period. IMO different apps of different classes should possibly have different times. A simple clock widget (for example) takes far less time to "test" than does a game or, in your case, a theme.
I see that is beneficial however it doesn't allow you to find out does the app work well on your your phone, the app may look great on your pc then you buy it and it work poorly on your phone.
The new refund policy actually keeps me from buying apps. I agree that an hour would be the sweet spot for most applications.
