Accessories 1500mAh battery for htc inspire.
stroja62
so as im sure all the inspire users know, the battery life sucks. if i buy a phone that can do everything the inspire can do i should have to stop using all those features just to save the battery. i found some 1500mAh batteries on eBay.
1
2x 1600mAh battery + Wall charger for HTC Inspire 4G | eBay
obviously they are not original htc parts but is it ok to use them in the phone. will it damage the phone. will the regular charger work for it or would you have to take it out and use the all charger each time.
hey thanks. i just got the phone yesterday so i am new to this site. what do you think about the replacement batteries tho. some people said they found good ones and some people said they sucked.
i think its a gamble buying the china batteries. might get a decent one (although it might only be as good as the stock htc battery) but you might also get one that doesnt last as long might only be like 900mah or whatever. Kind of like buying an sd card from china is a bad idea as it is usually a fake formatted to look higher capacity than it really is. 32gb usually is 2gb.
i would say just buy a spare HTC battery.
