16 GB microSD Card
brodymon
I just rec'd my 16GB micro Sd card and inserted it into my phone. When I checked available memory it said 14.8GB available. Is that normal or did I get screwed from the website I purchased the card from. I would think if the card is brand new it would have 16GB available....
Does anyone know?
Its normal. The formatted size of a memory card is always less than the advertised size. Same goes for Computer hard drives as well.
I checked my new 16gb micro card the other night and same thing.
This is what I found:
There are two main reasons why there is a discrepancy between listed capacity of the memory card and what shows up on your computer. The most likely reason that your 512MB memory card shows up with only 485MB worth of capacity is due to the small discrepancies in algorithms and file formats by various operating systems. Also a portion of memory space is reserved for system files and data sectors for better memory card performance.
The second reason your card indicates less capacity on the device is due to capacity loss. When manufactured, some devices and card readers were not made to support higher capacity memory cards. An instance of this is 2 GB or higher capacity SD card that shows a memory capacity of 1 GB or less. It is always recommended that you research information on the device manufacturer to verify the correct supported format and capacity.
Doesn't really help much, but on my last external hard drive, it was supposed to be 500 GB and was only something like 468 GB. I was pretty pissed about a 32 GB difference. :(
Who knows, probably a over promise, under deliver type situation.
Does anyone know?
They never have exactly the same amount advertised, my 8gig I think only had 7.4gig
for some reason manufacturers post the size of their devices as if 1000MB=1Gb
But 1024MB = 1GB
Then you lose some by formating as well.
so your 16GB sd card will lose 368MB right from the start.
Does anyone know?
If you don't mind me asking, what brand did you get and how much was it? Oh and what class is it?
Thanks
Does anyone know?
I bought a 16 GB chip and mine says same thing.
