Update is not available for North America yet. Sit tight. It will probably be anywhere from another few days days to another couple of weeks, but it'll come.
thanks for the update. so basically i need to check for update OTA every few days to see if it's available or i will get the update notification on my phone like i do with all the apps i installed?
i see that you are in canada. will canada and north america be available at the same time i wonder.
Oh and I should add, we are definitely anticipating seeing most updates coming within the month (November), so just keep a heads up here at the forums and I'm sure you'll see people talking about being able to upgrade or not![]()
When I check my phone's settings under settings -> about phone, I see that it is set tocheck automatically. I can only assume this would generate a message of some kind.Hello, long time reader here, finally joined the forum, I'm in Canada, I did the world 2.1 update thats posted over @ XDA, easy and to the point,. if 2.1 does not work out a 8+ months for 2.2 or 3, I'm selling my phone and saying bye bye to sony, I have no loyalty to any company so I'm good,.
I'm going to play with 2.1 for now and see what happens, I dont need any extra junk rogers may or may add to the update so I have no problem using the world release, just makes sense to me..
Thanks
Thanks
you in canada and did just did the 2.1 update via XDA? care to tell folks in canada and the US how to go about doing this?
No it doesn't. It's saying you can only flash to 2.1 and you can't flash to 1.6 with it.
Also, that flasher is for x10i ... if you have an x10a, it's really best just to wait.
For the record, I'm aware of how to do it, I just have no interest in flashing my phone, it's just not worth the bother for me. I'm patient.
, enjoy..Also, that flasher is for x10i ... if you have an x10a, it's really best just to wait
Im typing this from my x10a that I flashed using the x10i flasher. Everything works. Shows my model as an x10i in system info though. Oh well this will tide me over until a NA release.
