2.2 + skype, need to change input method after every reboot
TT_Vert
Member
Anyone else have this issue? When I power down and restart phone I have to manually go in and change to the stock keyboard and then back to swype. If I don't the blue trace will show but no text can be typed. I've read others had this issue and reinstalled. I uninstalled and reinstalled both the installer and the application per swypes instructions to no avail. This wouldn't be as much of an issue if I didn't swap batteries every day. Anyone else have this issue and resolve it?
Thanks
Dave
Thanks
Dave
THe solution is to download the hacked version of swype from xda. I'll let you search for it there. The beta swype suffers from the problem you describe above.
"skype" ;)
I would suggest a google search of something that may or may not include terms such as XDA, swype, and mic.
You may or may not find what you need in post #8...
