Well I went for 2.2 upgrade yesterday.
Did in place upgrade and all went well but the response was terrible.
The rear top right of the phone warmed up and battery life dived.
I uninstalled all the apps I could think of, thinking something had caused the problem but the rear of the phone still stayed extra hot.
Got to yesterday afternoon and the charger was actually only holding the battery drain at 50% and wouldn't charge the battery higher.
Did a phone reset last night. Loaded N2Manager SMS backup only to restore TXT. setup email (check every 30mins), turned off all location settings.
Unplugged my phone at 7am this morning. Made 3 VERY short calls. sent 20txt and battery has just warned of 15% at 10:50.
Im not sure theres much more I can do.
I ran advance task manager on it with 2.1 and although it wasnt great I could get 8 hours (just) out of it. I havent loaded advance task manager back on thinking it might be that but now the batterys finished in 4 hours Ill load it on and try. One intresting point that I found while doing a google is that with 2.2 maps keeps loading when it never did with 2.1 and Ive defo got all location options disabled.
Strangely rear of phone gets hot at weird times. Ive only narrowed it down to poor signal areas BUT it never did it on 2.1.
Any other ideas before I decided Ive got a working brick?
Tim
Tim
