Root 2.3.6 and Smart Actions changed
pm1066
Has anyone else noticed certain Smart Action "actions" disappearing with this update? Specifically, the action to shut off cellular data has gone away on Raw Dodge's phone, but is still present on mine.
Here's the relevant posts:. Raw Dodge, no cellular data option.
http://androidforums.com/motorola-droid-razr/443935-smart-actions-best-practices-3.html#post3812676
Mine with:
http://androidforums.com/motorola-droid-razr/443935-smart-actions-best-practices-3.html#post3813637
Also, is anyone else getting a market update notification for Smart Actions? I am--it appears to be trying to install the initial version.
Mine with:
The smart action version in the leak is 2.0.68 while the version in the market is 2.0.70. So it appears that the leak is running an older version of smart actions. If you are having problems with the version in the leak or are missing some parts I would say to go ahead and update to the market version.
I just installed the leak this morning. I still have cellular data too.
Is Calender Events new for Triggers? I dont remember that before installing the leak.
Mine with:
Cell data is still an available action for me. And as already stated the market update is indeed newer.
I did notice that the trigger "incoming call" is gone. I was hoping to see that and "outgoing call" as an available trigger.
