2 Android devices on one GMAIL?
mlamaral
Hi all - I just bought a Sylvania tablet with Android 2.2; I also have a Samsung Moment phone. when I tried downloading some apps to the tablet, it told me to sign in, so I did with the existing account. Although I was on the tablet, the apps started downloading to the phone. Any ideas?
I would say that you should check the sync settings on the tab, make sure it is set to sync to your account. They should dl to both the phone and the tab... (I don't have a tablet, so it is just a thought...)
Yeah, don't set up a second gmail account. With one you can use your paid apps on each device, if your tab downloads an app you don't want on the tab just on the phone just uninstall it.
