Integraoligist
Ok, I just got theEvo last Tuesday and it's been working perfectly except for these 2 issues.
2 days ago I was using the Google Navigation (and when I do this I always have it plugged into the car charger)... well apparently it uses more juice then it receives from the charger! Have never seen this problem in any other of my smartphones. So, while it's plugged in and i'm using GPS, the battery is die'n. WTF is going on?
Lastnight I charged the V to 100%.... took it off charge, and turned the phone off. So that when I wake in the morning to go to work it's still at 100%. Well I get up today and try turning it on and... nothing. Wont turn on. I can see a very very dim red light flashing so I plugged it into the charger again and tried turning it on.... and now the red light is bright and blinking at me. About 20 seconds later the red light stays solid (like it's charging normally). 5 minutes later I can turn the phone on, I unplug it to check the battery, and it says it's almost 1/2 full.
What is going on here?
Thanks all!
Thanks all!
