sph90457xp
Hi
I have 2 issues with my galaxy s i 9000.
1) you can only use the o(9) key if you turn the phone sideways.
2) the phone twitches alot and the grey bar at the top of the screen slides down the screen on its own accord and then randomly selects apps or different options on apps you are using. It also auto zooms in and out without you touching it like it has a virus or something. Reboots dont appear to fix it - any ideas ?
