Help 2 problems im having with the precedent.. please help me fix them..
I have no contact display pics. It is synced with my Facebook. I have the arearom 2.3.7 greenbread installed. I was able to have them on other arearoms.
Also the factory google search widget, the go search widget and the search button does not work...
mine is the same way.. check an make sure your videos are playing on youtube because mine wouldn play videos or anything.. but i found reinstalling really helps thats all i had to do. but my google bar doesnt work still..
Sometimes you just need to reinstall the rom, not sure why but everything just doesnt seem to take sometimes.
