Root 2 questions
G2435
first question i went to see whats been using my battery and the display has 74% how would i take that down and all whats better in battery life nitrous or classic right now im running nitrous
you use 74% of battery for display but for how long? 30minutes, 10 hours?
turn your brightness down as low as you can.
About nitrous or classic, I cannot say but roms only have little effect on battery life imo.
Kernels, usage, display, signal, updates, syncing, to name a few have effects on batt. life.
Edit: for example: Since uplugged 11hrs, 26 min. so far and of that time, 12% was used by the display.....
[/IMG]
i.e....1 hr. 54 min. my screen has been on...
[/IMG]
It been 2hr 28 mins still 74 percent for display and can I use underworld kernel eith nitrous or what's a good kernel
Honestly, just ignore how the battery stats are reported in terms of what is using how much %. Sense roms always have display super high. AOSP always has it low. Sense is probably more accurate IMHO. But as long as you don't have wakelocks, then that's what's important. Use Battery Monitor Widget by 3c to track your battery stats. If your phone is sleep in the -20 to -26 ma range, then you're in good shape. If you're lucky, you can get down into the teens. It's a great app, definitely check it out if you're not using it already.
Yeah I have it already installed and how would I know if my phone sleep is in them ranges
Click on the widget and then "history"...on mine, it's the column to the right of the time listed....like mine was sleeping just now at -26, which is good considering it had only been sitting there for like 10 minutes. Last night overnight I was between -21 and -29 all night. Usually closer to 21 than 29.
