Hi
I am using spice mi-310 android mobile. But its battery (1200 mAH) is very weak. Can anyone help me find out a better battery of 3.7V, 2000 mAH or more ?
I have some batteries that have 2000mAh on them that fit inside the factory battery door but the actual capacity is pretty close to stock in real world use. I don't think you will find anything that will offer longer battery life and fit inside the same battery door because the OEM battery is pretty solid with Li-Ion cells as it is so not much room to fit much more capacity.
