All of a sudden my Tab 10.5 starts and stops charging every one or two minutes. Charging 7 hours overnight only charged to 50% (from 25%). If using the tablet while plugged in and "charging" the battery actually LOSES charge.
This occurs with stock charger as well as multiple chargers (other chargers have higher output as I am aware of the higher current draw of the tablet). This also occurs with the stock cable, as well as multiple OEM cables.
I reset the Tab to factory defaults.
Not sure if this is the cause, but I recently did an over the air upgrade to 5.0.2.
Any ideas?
Any ideas?
