generatorlabs
I have followed some pretty decent guides on how to bring the LG Lucid up to Jellybean and for the most part I got it to work by following threads in this forum. Thank you for posting that information.
Here is my dilemma. I have about 25+ LG Lucids that are still perfectly good phones. Unfortunately they are all on 4.0.4. I have an Enterprise app from corporate that I must install on these devices. The only catch is they must be 4.1 or higher for the app to even install.
So I have 2 choices...JB and go to 4.1 or scrap the 25 phones and get new ones. I prefer not to fill a landfill with perfectly good phones. It's crazy talk.
So then whats the problem you say? I have a glitch that I cannot seem to solve. I have literally spent 24 hours trying to get the Lucid to comply. I must also admit that I have little to no experience with JB'ing phones. I have reflashed this thing no less than 8 times. I always start fresh at GB and work my way forward, step by step. My problem is this. I do not use external SD cards with these. When I am at Gingerbread the Camera and other apps can connect to some virtual sdCard partition/pointer with no problem. Once I get up to 4.1 using: cm-10-20130823-UNOFF, gapps-jb-20121011, and baseband Lucid-V8 some apps and especially the camera cannot see the internal sdcard any longer. The enterprise app I am trying to install somehow tries to access the sdcard partition too and cannot.
It is really weird because after the phone boots I can see it mounting an sdcard or some virtual form of it. The message appears on the top of the screen as it prepares it.
So I have pulled out enough large clumps of hair and I now mercifully ask one of you to help me get through this. From what I can see thus far I think this phone will perform fine with 4.1 if I can get this one wrinkle ironed out.
Thanks in advance
PS. I was using this guide to get me through the install: https://app.box.com/shared/hpapn930pad7afw85bth/1/495893161/8418413730/1
Thanks in advance
