who wants to take one for the team with this one?
I might as well order it.. it can be any worse than the stock battery..![]()
"When you receive your new battery, take it out of its packaging and insert it into your electronic device. Turn your device on and drain your battery until youre left with 1 bar of power. Then charge your device for a minimum period of 12 hours. Your first charge cycle is very important, do not charge it before it is down to 1 bar.2) After you have completed the initial charge, your battery should only be recharged once you drain it down to 1 bar of power and should be recharged for a minimum period of 6 hours for the battery to reach its full capacity"
or else what?
Just got the battery in today... going through the killing and charging procedure so my phone doesn't blow up ;-)
lol, Same here, Ive been using my QCell Extended Battery, love the battery life but damn!!! SLIM is in!! lol!If the battery turns out to be decent, I will definitely get it as I really want to go back to a slim phone.
Haven't had the chance to really test it but normally with my stock battery i need to charge the phone every chance i get.. with this one, it's now 9:30 pm, i am at 30% and i haven't charged it once today..
it does overheat a bit but not as bad as the stock.. the temp that the phone is showing is wrong though..
So i tested the battery. I charged each battery, calibrated it, and played a video on you tube using 4G.
From 100% to 15%:
The stock battery got me 2hrs 10 mins.
The ecell 2680 got me 3hrs 16mins and did not heat up as much but still got pretty warm.
And for those of you more interested in what video i played:
HEYYEYAAEYAAAEYAEYAA - Full 10 Hours - YouTube
