Help 2g 3g 4g toggle
jjro80
Hi, do you know any simple app that i can change from 3g to 4g without having to go to the settings? i ve search google play and didnt find something like that, i have huawei p9 lite.
Their are several widgets that do this in the play store. Just do a search and pick the one that is best for you.
I have a problem with this suggestion.
He wants to switch between 2g, 3g, and 4g on his telco carrier.....
I fail to see how a WiFi manager can do that??
I used to have that program installed, and quit using it, no benefit to it.
WiFi360 is far better.
http://wifi.360.cn/ ? That's Beijing Qihoo 360, so if concerned about privacy, I would avoid...see also Cheetah Mobile. :thumbsupdroid:
Thank for your answers, it doesnt seem that there is a simple app that change easily from 3g to 4g... and it seemed so simple...i ll go to setting to do that ...
Could be because it's not something most would normally need. So it's not quickly accessible as a short-cut, and nobody wrote an app.
I just leave it to the phone. 4G LTE is the fastest internet, but if that's not available, it goes 3G, or even 2G, like when I'm out in the grasslands.
