Help 2G Mode
wish there was a simple app to do this as i wont remember that number is there anyway to make a simple app that will do this ?
there is away but you have to do a Total Phone Transfer witch is a
Using TPT allows you to change all of the sections of your phone in one single install. This means that the BOOT, RECOVERY and ROM all get installed together.
TPT also has the power to change other much deeper parts of the device; the first discovery has been that you can change the partition sizes.
youll need to download x850_1.1???.rar|??|115??|115??U?-????|??????
then look on google for a file called USDL it the program that flashs the Total Phone Transfer files go here
Google Translate
so far i only no one way of doning this:(
and thats with Secret Dialler Codes
type this into dialler *983*0# it will bring you to a menu click the one thats says radio info then change the set preferred network type to gsm only
Thanks a TON!!! You don't know since how long I have been searchin for apps to select GSM only!!! Cheers
