followmylogic
So I have the Vivid (obviously) and I've been having some problems with it for a while now and cannot seem to find the answers by searching.
1st problem
Some times the speakers won't play sound from videos from online sources (Ex. Youtube) The only way of fixing this is to restart my phone
2nd Problem
After Restarting my phone it goes into the updating applications screen (every time) It has some 37 applications that it updates. I'm not sure what those 37 are or why its only those and not all of them.
3rd Problem
I have a 32 GB microSD card in the phone that is almost full of music. When the phone is done updating and starting after it has restarted it won't read the apps or any other files stored on the SD cards (the internal as well) The only way to remedy this is connecting the phone to my computer and hitting the mass storage device option. Then going to charge only and unplugging. I've already tried formatting the SD card with the phone and that didn't work.
These issues are fairly annoying but aren't major problems because they can be fixed. It's just annoying to fix them.
The phone is updated to 4.0.3 if you need any additional info please ask.
1st problem
2nd Problem
3rd Problem
