Help 3 simple questions
eric0668
1. I can't find weather toggle widget. Neither play or apk. It seems to be deleted. Is itbaround. All I used was the toggle bars LOL. Looked to work like Beautiful widget but didn't. I emailed them but got no response
I would use another Appt if one exists. I tried power widget burning want the specific number of brightness at several intervals. Any ideas?
2. Is there a way to turn wallpaper scrolling on or crop it to the full size ofbthe wallpaper b
The GN was fine at the same resolution. But this sometimes does not. Inforgot what size, 960x800, 1260 or 80 x 7??, or 1440x 1280x760 but one of those leaves blackness on the sides of the wall when you scroll all the way left or right
3. I know this is subjective can someone tell me if Apex or nova is considered launcher? Or should I try Go Launcher
Thank you much
Eric
