[3D Measure] It's a tool which perform non-contact distance measurement by using camera and hardware sensor of device.
Quick estimation of the distance to any object and the object height and width.
BEFORE MEASURE:
1. Set the camera height above the ground plane
2. Set the measure mode,height or width
3. Aim at the bottom of the object
HOW TO MEASURE:
1. Distance: Aim at the bottom of the object and "tap" the circle button
2. Height: Aim at the bottom of the object and "press" the circle button. Rotate the device slowly, aim at the top of the object and "release" the circle button.
3. Width: Aim at the left bottom of the object and "press" the circle button. Rotate waist slowly, aim at the right bottom of the object and "release" the circle button.
KEY FEATURES:
1. Estimation of distance to the object
2. Estimation of the object height
3. Estimation of the object width
4. Easy to set the camera lens height
5. Easy to set the measure mode
6. Simple calculator to calculate the object real height and width
7. Camera auto focus when touch screen, press or release shutter
8. Sensor calibration reminder
9. Keep screen awake
10. Supports six measurement units and unit conversion function
web google market
mobile google market
BEFORE MEASURE:
HOW TO MEASURE:
KEY FEATURES:
web google market
