Help 3G bug
Lewisfall
I updated the firmware on my galaxy s yesterday and now I seem to have very low signal and can't connect to the internet unless it's via a wireless router.
Had any one else experienced similar our can anyone talk me through a simple settings check to make sure there's nothing more sinister going on with my phone?
This is, until this update the best hand set I've had, and I want it back like it was!
The first thing to check is your Date settings, when you update your software, it sometimes happens that your service providers 3G settings are changed.
Go to your SP's web page and you should be able to get the Data settings from there, and then reset them on your phone.
Hope that this solves your problem.
