Cousin2011
3G symbol disappeared from on top of signal strength two days ago
It shows no symbol at all
I don't remember hitting any setting by mistake
I'm with Vodafone in Australia and up til couple of days ago data worked fine
I have 'Mobile Network' set to on
'Network Mode' is set to GSM/WCDMA auto
'Enable always-on mobile data' is set to on
'Access Point Names' is set to VF Live (live.vodafone.com)
Wifi access at home works good, but once I go out of the area there's no data available through mobile network
I've been trolling through the threads here, can't find anything that helps me
I don't know if it's related, but three times recently my bill shows data connection around 4 to 5 hours, and I was browsing the web leading up to these times, but only for 10 or 15 minutes each time
So when I finish, I use the back arrow bottom of the phone which takes me out of the browser
Is there some other way I should finish so I close the internet connection, and not rack up additional cost
I need to check my phone settings first before I go to VF and see if they have put a restriction on my account. No problems with them prior, and yes bills are paid! and there is lots and lots of data still available
Thanks,
M
oh, just remembered, I have full signal strength at home (yay!!), two others phones at home on VF have 3G showing, and I have the same no symbols showing wherever I go in the state, over the last few days
Thanks,
M
