Help 3G connectivity problem? Please help....
galaxtus
Hi guys, I am using Airtel 3G from past 4 months without any problem. But from past 2 weeks i am having problems. Call & messaging works but when it comes to internet it is not connecting, it show connection error. I contacted airtel but they are saying nothing is wrong with there side. They told me there might be a problem with my Phone. Please help.....
Have you confirmed your APN settings are correct?
Settings -> Wireless & Networks -> Mobile Networks -> Access Point Names, you'll need to find out what the correct settings are, then check them against yours.
Hey guys, i installed Network Info app...
When i am connected in 2G (Edge) it shows it is Network Type: Edge.
When in 3G it shows Unknown....
Is there any code or setting i can check this maybe correct it. Is there any file in system that i can check....
