3g dongle not supporting
  • Thread starter Thread starter shivambhadauria
  • Start date Start date
S
shivambhadauria
Guest
hi i am currently using haier tablet pad821. i brought it from china. i am unable to use 3g dongle for net connection. i was told it will work on 3g dongle. it works fine with wifi network.
it doesnot have mobile networks or APN as it doesnot have sim card slot. so i want help on that................
all the suggestion are heartly greeted...........
Well, first I believe you will need an OTG cable to connect the dongle to your Tablet. Then I've seen some people have luck with the following process, but it requires rooting your tablet and some other technical steps.
http://forum.xda-developers.com/showthread.php?t=2172914
A simpler option is probably to pick up a 3G wifi router and plug your dongle into that, then use your tablet's wifi to connect to the network.
I hope this answer has assisted you with your issue! Please note that if you have any questions you can easily resubmit another question using the same “ask a question feature” and one of our staff experts will quickly assist you. If you prefer to have an interactive response please feel free to register with android forums. It is free and we have a wonderful community that is dedicated to helping each other with any questions you may have!
Register today!<----Link
